Help To Find Plastic Ware Strips
/ Help To Find Plastic Ware Strips #1
Old Pipe Welder D
Ontario, Canada
6400 JD : : 150 NewHolland skid steer, Case TR-270 Skid steer
I bet there is another name for this material, but I want to add replaceable ware strips between two pieces of steel.
any ideas what its called or where to order it?
Thanks ahead!
/ Help To Find Plastic Ware Strips #2
It's call Ultra High Molecular Weight Polyethylene, UHMWP for short. Here's the first site I came across UHMW Sheet | UHMW Sheets | Plastics International . The stuff is slippery for sure, I've used it for numerous applications at work from 1/4" thick for sliding gates on a salt/sand hopper to over 2" thick for sliding a 140+ ton vehicle ferry on.
In the ferry application (Englishtown Ferry - Nova Scotia Image) it was too slippery and it couldn't be used. It was supposed to stop the wearing of the abrasion strips on the bottom of the ramp, which it did. Only problem the ferry was too hard to keep docked without constant power and it had to be removed.....Mike
/ Help To Find Plastic Ware Strips #3
I think this place carries a product that is a type of plastic and ulta slippery. A few years back I used some for a wear shin on a plow and I am near certain this is the place I got it.
/ Help To Find Plastic Ware Strips #4
what place is that?
/ Help To Find Plastic Ware Strips #5
This is a place I use http://tinyurl.com/cylmmpw . They have an area out front where the off cuts are, they don't give them away but it's a great souce for odds and ends. I've also bought some clear and smoked Lexan there to makes lowers for my bike.
I try and time my needs when I have to pick up something for work and a lot of times they'll just give it to you, depending on size of course...Mike
/ Help To Find Plastic Ware Strips #6
Grainger Has it also. look for UHMW plastic
Interesting story about the ferry... I think I was on that going over to Cape Breaton Island.
Thanks guys, I now know what its called, I just need to find some here in Canada, I see Lee Valey sells it in small pieces...Thanks
D
/ Help To Find Plastic Ware Strips #8
If you have a place around that has anything to do with dirt track cars they use 1/8" thick plastic that is pretty durable. It's not quite like Tyvar (like what you would use between the truck and trailer on a semi) but a lot cheaper.
/ Help To Find Plastic Ware Strips #9
A lot of cutting boards are made from UHMW and can be had in many thicknesses. A food equipment supplier will have larger and thicker pieces.
/ Help To Find Plastic Ware Strips #10
/ Help To Find Plastic Ware Strips #11
Yep, goes across St Annes Bay. Nice place...in the summer, in the winter with the ice coming/going they have to pull the ferry up so the cable doesn't get snagged. It's a cold place to work as well in the winter, windy, it'll blow you all the way to Newfoundland .....Mike
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
2007 Peterbilt 378 (A62679)
2007 Peterbilt 378...
2022 EZ-GO ELITE...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
