5045E...anyone own one of these?
   / 5045E...anyone own one of these?
The shop is 40x30 with an 8 ft extention at the 10x10 tractor door, the other 8 ft is coverd porch area in the front.
   / 5045E...anyone own one of these? #12
Wonderful Job!! Is that forward rotation?? Looks great. :)
Did some tilling last night......I like it!
Yes...forward rotation. The King Kutter is 6ft. and does an awsome job. They are a little pricey, but I think one should last a good while. They are gear driven.
   / 5045E...anyone own one of these? #14
Yeah, I bought one about 1 1/2 years ago. I love it. Me friend talked me into getting the bigger tires and I have no regrets.
   / 5045E...anyone own one of these? #15
   / 5045E...anyone own one of these? #16
I thought the E was also MFWD only until I saw several 2wd E series tractors. Looks like to me the E designates the hydraulic brakes and the 9x3 transmission.
John Deere 5075E Tractor For Sale - YouTube
Here's a quote from deere's website..."While the 5045E and 5055E feature standard mechanical front wheel drive (MFWD), the 5065E and 5075E are available in either 2WD or MFWD configuration." It appears you can only order the 5055E in a MFWD version...
   / 5045E...anyone own one of these? #18
is there a big difference between the 9x3 vs the 8x4 transmissions? Besides one being a shuttle shift and the other being a synchro shift? is the 8x4 "faster" then the 9x3? my friend has a 5105 2wd with the 8x4 transmission and that thing is a freaking speed demon! seems fast in every single gear to me.
   / 5045E...anyone own one of these? #19
I assume that grapple's a Deere(or Frontier?) Is it JDQA or SSQA? And how much did it run you?
Also curious about the grapple. Width, how it is tied to hydraulics, satisfied, anything you would do different?
   / 5045E...anyone own one of these? #20
I have owned both. Like the low range of the 9/3, but liked the shift/range lever locations better on the 8/4 and seemed like picking the gear and shuttling back and forth between fwd and reverse kept speeds closer to the same with the 8/4. With the 9/3 I find myself running "B" range in "2" for loader work and the Reverse in "2" seems a little too "tall" for my preference. Find myself wishing was a touch slower.
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
2015 FONTAINE VELOCITY 102" X 48' STEP DECK TRL (A50459)
2015 FONTAINE...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51242)
KNOW BEFORE YOU...
2012 Ford F150 Crew Cab Pickup Truck (A50323)
2012 Ford F150...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A51039)
Morooka MST 660VD...
