Engine Flooded with Fuel
/ Engine Flooded with Fuel #1
Clumber
Gold Member
Northern Virginia
Kubota B2601 HST Nov 2019
Tried to start my PT425 today. It seamed like battery was low, so tried to jump start. Noticed fluid leaking from air filter cover. :eek: Immediately removed battery cables, etc just as the gas fumes became strong smelling. My retired mechanic neighbor and I drained almost a gallon of gas-oil mixture from the engine. The oil filter and the air filter and pre-filter were soaked in gas. An old fuel shutoff from an old lawn mower was installed. We are letting the engine sit the afternoon and overnight to hopefully dry-out. Tomorrow we will replace the oil and filters and charge the battery. I will report back on status.
This the first serious event I had with the PT. It would have been a disaster had I not noticed the seeping fuel, sat in the chair with my back to the engine and tried to jump start-crank the tractor.... From now on I use the shutoff valve and check the condition of the oil via the dipstick before starting the tractor.
/ Engine Flooded with Fuel #2
Pull the sparkplugs too, let any gas inside the cylinders evaporate.
Time to mount a fire extinguisher on your tractor, if you don't have one already. Makes the difference between a $20 event and a $8000 event....
Thanks for the advice Tim. Forgot to mention that we also pulled the plugs. I am going to give it another 24 hrs to dry - its kinda cold today. I have a small fire extinguisher on the FOPs, but I think that a larger one will be purchased soon.
/ Engine Flooded with Fuel #4
Did you do anything about the leaking carb?
Probably need to replace the float needle and clean the needle seat. That is where your leak is coming from.
Thanks JJ. Well my mechanic put it all back together this afternoon with new oil & filters. He used carburetor cleaner and adjusted the needle and float. He didn't think it needed to be replaced -might do it anyway. Cranked it over a few times to distribute the oil. Earlier, I had charged the battery from 75% to 100%. The PT started reluctantly after three tries and blew drops of oil and smoke from the exhaust for a few seconds. Ran for ten minutes, then stopped to check an top-off oil. Restarted it easily and ran for 30 minutes. Seems to be running smooth with no issues. Will retest tomorrow. The mechanic said the fuel pump works off a vacuum and can become stuck and not shut the fuel flow. The newly installed fuel shut-off valve should help.
/ Engine Flooded with Fuel #6
Just curious what color is the smoke that you saw?
The smoke was bluish at first, then a more normal whitish color you see with the choke engaged during a cold start.
The PT started easily yesterday morning after checking the oil and opening the fuel shutoff valve. It was 30 degrees F. We used it all day prepping for the heavy snowfall expected tonight. Heavy pallets of firewood were moved closer to the house. A large portable generator was strapped to a pallet. Then we built a three sided plywood shelter on the pallet. This portable pallet generator + shelter can easily be moved using the forks if power is loss.
Installed studded chains on all four wheels. Attached the snow blower, and backed the rig into the garage ready for action. Will have to clear a mile of private stone road (crusher-mix) and about an acre of dog-run paddocks. Its all fun for a while. Afterwards, will have to take Advil and have a nap.
The PT-425 seems to be operating normally. Looks like I dogged the bullet this time.
Sure sounds like your getting things figured out with your PT.:thumbsup:
Well I get a lot of guidance from this forum off course. It's also nice to have a retired auto and small engine mechanic as a friend living near to keep me out of trouble.
/ Engine Flooded with Fuel #10
A fuel shut-off valve should be mandatory. It would certainly solve a lot of carb problems!!
/ Engine Flooded with Fuel #11
We used it all day prepping for the heavy snowfall expected tonight. .
Snowquestration is coming!
I need to do that when I get home. Glad you mentioned it, I would have forgotten about chains. I will drive my PT422 around, and run my generator for about 15 min.
/ Engine Flooded with Fuel #12
Snow update from northern Indiana...
It ain't doing diddly!
Light snow. Still see the grass. Melting as it hits the streets. Supposed to be gone tomorrow. Typical winter day for once.
LOL! The potential for heavy snow here sorta took my mind off the other gathering storm in Washington and its possible impact on my job...
/ Engine Flooded with Fuel #14
Snow's over here. Maybe 5" of fluffy stuff on top of an inch of icy stuff. Nothin' to write home about. Hope everyone else gets it light, too.
/ Engine Flooded with Fuel #15
Patrick (Clumber)- How much snow are you getting? Forecast here in DC is for 8", but I doubt it. Too warm. Got about 1-2" so far though.
My PT422 is ready, though. Pretty happy that it fired up without a hitch yesterday. Haven't run it in over 2 months, nor charged the battery. I bought a new battery last spring, and I think it made all the difference in the world.
/ Engine Flooded with Fuel #16
They are talking light rain in Los angeles and 60 degrees. Town is in a panic, buttoning down for the worst. You gotta love the west coast.
Hi Tim, We got 12 inches overnight. Light snow since 7 AM, hardly any more accumulation since. Ran the PT with snow blower for 2.5 hours this morning. Works great, no problems so far. Easy start this morning. About to start on the driveway/road. The power flickered a few times, but no outage. I think Front Royal and a few neighbors around here have no power. The trees here were heavily laden early but as the wind picked-up they are okay now.
/ Engine Flooded with Fuel #18
wow, impressive. We have 2" of slush, but still snowing. Not enough to plow.
Guess the DC hot air bubble protected us again. 20 miles away got 10". Inside the beltway: 0.5".
/ Engine Flooded with Fuel #20
Rain in Vegas us nothing to mess with. Friggin monsoons will surprise you and wash you and you car down Las Vegas blvd.
2016 BOBCAT T740 SKID STEER (A62129)
2016 BOBCAT T740...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A61306)
2019 Takeuchi TL8...
2013 Freightliner M2 Bucket Truck (A60352)
2013 Freightliner...
2004 PSI M413XT Maintainer Motor Grader (A59228)
2004 PSI M413XT...
2025 30in. Pallet Forks and Frame Skid Steer Attachment (A59228)
2025 30in. Pallet...
2013 Ram 5500 Bucket Truck, VIN # 3C7WRNALXDG552597 (A61165)
2013 Ram 5500...
