Ideas on how to move a shed...
/ Ideas on how to move a shed... #11
Second that.
I have done the skid and drag and it worked well. But made the platform so that the building just rested on the platform. But if u don't have the timbers, then the trailer option would probably be the best as u are not buying something u don't need. Some of the buildings around here are made on skids. On those, I would think u could hook to them and drag them 500 yards.
Shed does have a wooden floor and is mounted on 4x4's. Not sure if there runnin lenght wise or side to side. Lenght wise would be better.
I suppose i could rig up something going to my 3pt and lift it then drag it home..
/ Ideas on how to move a shed... #13
Frugal is good ,500.00 is cheap . Now drag it down the road 500 yds and you will have a kit to reassemble , but it won't be in the.packaged form . Call the shed mover .
/ Ideas on how to move a shed... #14
How about some skids ... old telephone poles, 6x6, 4" pipe ? Get them under it and drag her home.
Exactly what I'd do!
Use skids about 3-4 ft longer than shed and fasten firmly cross bars (spreaders) front and back.
Taper the fronts of the skids so that they don't dig in.
If you are crossing sensitive areas (flower beds, walks etc) lay old 2 by stock for the skids to slide on, even old punky plywood is also good.
Hose down surfaces that the skids slide better.
Should be very easy to do.
Good luck and have fun.
I will get this shed home on my own, and in the same shape b4 the move. Mover wants $250 for less then a hr's work including his travle both ways....
Theres only one turn I have to make out of his drive, and then its straight shot into my drive. Then have to back it up 80' or so to its new home. I'll look under it this week to see if the 4x4 runners bolted to the floor and going lenght ways. If my neighbor can help me with his tractor, I'll use mine and my equipment trailer.
/ Ideas on how to move a shed... #17
Around here, a towing company (or preferably a small shop) with a rollback wrecker would do that move for $100 on a slow day.
Aaron Z
/ Ideas on how to move a shed... #18
If your tractor has a FEL and the Kioti of your neighbors does, it would be so quick and easy to just raise it up, back the trailer under it, then use both tractors to unload it. Much less danger of damaging the shed that way
/ Ideas on how to move a shed... #19
I like this thread. I can imagine all of us standing around at the OP's place with our coveralls on, bud or coffee in hand discussing how to move the old shed.
"Well I remember back in 78 when ole Clem Smith had to move a shed just like this. Cept his shed had tin siding cuz Merle Barcklay used to keep chickens in it and the weasels was a chewin thru the wood siding."
"Geez, I'd forgot about ole Merle, what happened to him after the wife moved out and he left for Tuscon..."
5 hours later no work would have commenced!!!
/ Ideas on how to move a shed... #20
My neighbor has a kioti, so lifting from each side to run the trailer under it would work....
thought about lag bolting a 6x6 under it and draggin it, but I think it would bust the shed up...
After the skids are in place lay another crossways over the two just at the back of the barn and drag her home. The cross member will keep the building on the skids
Hustler super Z zero turn (A56859)
Hustler super Z...
2017 PETERBILT PB337 HYDRA-TAIL FLATBED TRUCK (A59823)
2017 PETERBILT...
2009 FORD F-150 (A60736)
2009 FORD F-150...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
1992 VIM TRAILER MFG CRUDE TRAILER (A60736)
1992 VIM TRAILER...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
