Diff lock problems
/ Diff lock problems #1
Does anyone know how to adjust the diff lock on my 3316. It seems like when I press the pedal down it won't lock into position and only one tire spins. I've read a few of the posts and tried a few of the different ways to try to lock it in but it feels like it just spins past. I could have sheared off the gear also so if anyone knows how to replace that it would be great. Thanks.
/ Diff lock problems #2
The adjustment is in the linkage on the opposite side of the pedal, just in front of the axil.
/ Diff lock problems #3
I had a similar issue with my 2216 that only one tire would spin with the differential lock engaged. The tractor also had a problem moving forward if there was resistance. The rim was spinning inside the tire bead and I couldn't see it from the seat. My dealer figured out what was going on and I linked the findings in my post below. It may or may not be your problem, but something easy to check by just marking the tire and the rim with a dot of paint.
http://www.tractorbynet.com/forums/...earing-snow-ive-got-question.html#post3187633
/ Diff lock problems #4
if they are anything like the 3215's, they are know to break the cog in there and would have to be repaired.
Found the adjustment. Tweaked it about a half inch tried it on the first snow bank and both tires were spinning no problem. Thanks alot for the tips everyone.
