replacing a front hub
/ replacing a front hub #1
irishgb
SC
BX1850D
has anyone replaced the front hub on a BX1850D ,wondering how much is involved . also wondering if the crack in mine is a common problem ?? thanks
/ replacing a front hub #2
Have a picture?? I just replaced the seals on my axle front pivot points and if it is this are, there should me no issues.
Thanks No picture yet but it is the lower hub that holds the wheel and I will replace the seal (that allows it to turn) also . Did you replace one seal for each side ,or the seals (O rings) on the center pivot ? Irishgb
2005 Little Wonder High Output Walk-Behind Blower (A64553)
2005 Little Wonder...
ATS 40 Gallon 2 Stage Air Compressor (A62679)
ATS 40 Gallon 2...
2025 Swict 84in. Bucket Skid Steer Attachment (A64553)
2025 Swict 84in...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2022 JCB 509-42F TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42F...
Quick Attach Concrete Mixer (A65579)
Quick Attach...
