BX2360 Upgrades
/ BX2360 Upgrades
Here are some pictures of the grill guard compatible weight bracket. It had to be mounted up high so I could go over uneven terrain. The bracket, grill guard, and hardware weighs 47lbs.
Lifting the grapple with the front firmly planted:cool2:
/ BX2360 Upgrades #43
Roger,
Looks great and should be a real help with heavy rear loads. Nice bracket design too.
/ BX2360 Upgrades
Roger,
Thanks. I am glad I decided to make my own and keep the grill guard. The Kubota bracket would have let the weights drag in a lot of places.
/ BX2360 Upgrades
My neighbor who lives across the road saw me out running the BX around one night and he said the LED strip light was really bright. He also saw me in the day time and said it was still really visible. It should be a lot safer mowing along the road with it.
I rewired it just like the one on the L4240, on with the headlight and flashes with the 4 ways.
Here some better pictures with the lights adjusted. Pictures don't do them justice.
Just the headlights
Both forward facing LED's on
Side shots
/ BX2360 Upgrades
I added a battery mat to the BX. It aborbs the acid
Cut to fit.
/ BX2360 Upgrades #51
I am making a thread for some stuff I want to do to the BX. So far I got a grille guard of ebay and a Harbor Freight qh.
I am confused. Is that a Harbor Freight quick hitch with "Kabota K Match" painted on it. I have been thinking the HF quick hitch will not work on my BX2200 because it is 27 1/2" and the BX requires a 22".
/ BX2360 Upgrades
Yes it is a harbor freight quick hitch. I believe the BX 2200 is a limited cat 1 3PH so this will help give you more lift.
/ BX2360 Upgrades #53
Nice going Roger. Lots of great tips. You've made some nice improvements. Thanks for posting them. :thumbsup:
/ BX2360 Upgrades
Thanks Paul I have a few other things I want to do to it yet I just need the time.
/ BX2360 Upgrades
Nothing major but I replaced the key rings on the side links with 3/16 lynch pins.
/ BX2360 Upgrades #56
Thanks for posting because every idea probably is a better idea.
Chris
/ BX2360 Upgrades #57
I just put the improved stabilizer bars on our BX2200 and BX2660 from Hodge yesterday and they are an easy improvement; always hated those turnbuckles. That along with Bro Tek plates and wheel spacers are the only improvements I have on ours, OK my wife's tractors.
/ BX2360 Upgrades
Chris
No problem.
I may make a set of telescopic stabilizers. I don't have much use for them since I have a quick hitch.
/ BX2360 Upgrades #59
Ah, but the seed has been planted and I know how you crafty guys are, you will probably build a set anyway...:)
/ BX2360 Upgrades #60
I just found this tread - subscribed. Some very good ideas here and the workmanship is something to be proud of. Thanks for sharing Roger.
-- Bill --
New/Unused Landhonor Electric Hoist (A61166)
New/Unused...
2018 HINO SA (A58214)
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
John Deere 1025R Tractor (A64047)
John Deere 1025R...
2018 Hustler Super 104 Zero Turn Mower (A63116)
2018 Hustler Super...
