How do you put ballast in your tires?
   / How do you put ballast in your tires? #22
4$ drill pump works fine...
   / How do you put ballast in your tires? #24
got mine from harbor freight...
it's loaded MANY tires..
   / How do you put ballast in your tires? #25
How many people fill their tires without using tubes?
I've got tubes in both my tires.
Wedge
   / How do you put ballast in your tires? #26
all my loaded tires are tubed...
   / How do you put ballast in your tires? #27
Mine are tubeless but are filled with automotive grade propylene-glycol anti-freeze and water.
   / How do you put ballast in your tires? #28
Will using the drill pump work to remove the ballast from the tires? I'm thinking of getting a set of turf tires to swap onto my B3200 for mowing - and since I already have loaded R4's - I don't see a need to have ballast in the turfs - but the guy who's selling them already has them loaded. I'd like to cut the tractor weight down and avoid rutting as much as possible. This would be easy if there were two fill valves on the tires...............
   / How do you put ballast in your tires? #29
physics will work for removingthe ballast.
pressurize the tire and then slip some fuel hose over the stem with valve at the bottom. have lotsa buckets ready.
I've found a rubber tipped air gun is the way to go.. apply a lil air to hose end and inflate the tire, and then let it 'pee' some more. keep doing this. have the axle supported too.
you will not get the last bit out under the valve stem doing this.
at that point.. if you have thin tubing that will fit down thru the valve you could then syphon or pump out the rest.
SET OF TRUCK FENDERS AND HARDWARE (A58374)
SET OF TRUCK...
2012 GALYEAN 160 BBL STEEL VACUUM TRAILER (A58214)
2012 GALYEAN 160...
2022 International MV607 Terex XTPRO56 56ft. Insulated Forestry Chipper Bucket Truck (A55973)
2022 International...
2021 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2021 Caterpillar...
12V 20GPM Gasoline Fuel Transfer Pump (New/Unused) (A59225)
12V 20GPM Gasoline...
INBOARD DRIVE (A58374)
