john deere 750 torque specs
/ john deere 750 torque specs #2
First 29 ft lbs, 2nd 58 ft lbs, last 72-79ft lbs working from middle toward ends. Rod bolts 16.6 to 20.2 ft lbs. I have basically the same engine as you in my ym2002d. It is a 3t80u-nap. This information came out of a ym220/226 manual which has a 3t75ha engine. Closest to my grey market per Hoye. I have checked out part numbers and know the head bolts are both m12. Part numbers are the same on rod bolts so I have confidence the numbers are correct and would bet a dollar to a donut they are correct for you also. Proceed at your own risk. :D
ok thanks , now can you tell me if fuel could be getting inti crankcase from the injector pump . I have fuel coming out from around the pump where the shims are . was told there are no gasket there just shims , so could the fuel be getting into crank case from there ? Have not pulled pump yet thats next . Thanks
/ john deere 750 torque specs #4
A few sentences on the Internet is a poor substitute for an operators and service manual. There are many more important specs to check.
1-800-522-7448
/ john deere 750 torque specs #5
Yes, fuel can get into the crankcase from there. If you have fuel in the crankcase that is most likely where it is coming from.
fuel is coming around the shims tried to tighten but was not loose so ill take off and check
/ john deere 750 torque specs #9
crankcase showes full to top mark
Are you sure diesel is not running down from the injector pump lines, either suction or injector lines? Reason I ask is that if your pump was leaking into the crankcase it should overfill the crankcase before it starts coming out around the shims.
just checked its bubbling out around base of pump where it touches block .
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
Pittsburg 4 Row Cultivator (A64119)
Pittsburg 4 Row...
2024 JCB 35Z (A60462)
2002 WACKER RD25 ROLLER (A59912)
2002 WACKER RD25...
4R CHISEL RIPPER BEDDER (A63291)
4R CHISEL RIPPER...
2024 Teagle Tomahawk 8500 (A63688)
2024 Teagle...
