Size of box blade for JD650
   / Size of box blade for JD650 #2
I had no problem with a 4' box blade on my 2wd 650. Yes, you can load it up enough to bog the motor down, but that's more a user learning issue, plus note that I didn't say lost traction. Used mine to maintain my gravel drive, re-contour the lawn, and many other smaller chores. Worked great!
PH
   / Size of box blade for JD650 #3
The rule of thumb for width of a box blade is slightly wider than the tire width. Anything smaller defeats the purpose, anything too big will cause other problems.
   / Size of box blade for JD650 #4
Indeed. My 855 is almost exactly 4ft with the wheels I have on back. While I might be able to get away with a 4ft, I use a 5ft. Gives me a nice overlap and for most things I don't have any issue pulling it. There are occasions of course where I just don't have adequate weight or traction but usually it's because I've allowed it to bite too much for the work surface/conditions.
That same box blade is too big to be of any use on my smaller Satoh Beaver. That tractor would be better served by a 4ft. With the 5ft it's almost too much for the tractor to lift and I cannot do any real work with it due to traction/weight issues.
2014 Doosan DA30 (A51039)
2014 Doosan DA30...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2025 K4230T UNUSED Metal Storage Shed (A50860)
2025 K4230T UNUSED...
2012 FREIGHTLINER CASCADIA (INOPERABLE) (A50854)
2012 FREIGHTLINER...
2023 Vivid EV Golf Cart (A48082)
2023 Vivid EV Golf...
