Hitches
/ Hitches #1
murphy1244
Super Star Member
Ohio
Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
What is the difference between a JD Quick Hitch and a JD I Match hitch? They are both in the JD catalog. :confused3:
/ Hitches #2
Doesn't one let you attach your bush hog, scrape blade, 100 gallon sprayer, pulverizer with you having to plug in the PTO drive shaft if you need one? The other has some drive shaft engineering built in. The price tag should give you a clue as to what does what. Maybe that is the auto hitch I am thinking about.
/ Hitches
The price difference is 38.00
/ Hitches
I match has a adjustable top link, that way you could use it on any attachment.
Thanks, I found out today I can't use I match on my Land Pride shredder due to the floating Top link.
/ Hitches #6
Thats goodtoknow. Deere claims it should work with any attachment. Ill pass this along to my lp customers
/ Hitches
If you buy 20lbs of hardware it Might work
2006 Ford F-650 S/A Dump Truck (A61568)
2006 Ford F-650...
MASSAGE CHAIR (A58214)
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A61569)
1990 21ft Center...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
1976 Athey Force Feed Loader (A61166)
1976 Athey Force...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
