What size FEL plow - Kubota MX5100?
   / What size FEL plow - Kubota MX5100? #11
BTW, what brand of blade is that you've got on your 5740?
Ironically, the angle plow is a JD SB9. It's a decent blade, but there are much better out there. I got it cheap.
   / What size FEL plow - Kubota MX5100? #12
I'd suggest compromising and go with a 7.5 foot plow. Our tractor/loaders are similar in size in weight, this what my 7.5 footer looks like from the front. Granted it sticks out a little further then a loader designed plow because its made for a truck. It pushed 2 feet of snow pretty well (Ag tires) but I can see why others would go with a seven footer. Also, do you have a garage? This plow just barely fits through my door without angling it, your garage door size may be a consideration.
Good thought, we have one door that is taller/wider but I always forget what it measures.
   / What size FEL plow - Kubota MX5100? #14
I think a plow that is suspended by a chain would be the best way to go after using mine a little. You can keep the weight of the loader on the front axle.
MULCHER (A58214)
MULCHER (A58214)
Propane Firepit (A57454)
Propane Firepit...
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
4 Inch Stargrip (A57454)
4 Inch Stargrip...
Wooden Side/End and Round Tables (A56860)
Wooden Side/End...
