B 26 backhoe running slower and slower
/ B 26 backhoe running slower and slower
I'm not clear on which way your controls are set up currently? It seems to me you figure, by bringing both controls back simultaneously and all the way back it should pull the grade you want. That's not going to happen. You may have to pull one lever back a tad more than the other and so on. Takes practice to get the feel of the controls to make them do what you want. IMO The best way is stick with what your most use too. I had to switch my dipper and boom to Cat style (boom right, dipper left) controls. Just not at all use to Kubota contols.
QUOTE]
I agree to an extent, but the way I have it set up now, the hydraulics are balanced so that they both move more or less in syncronous movement. Maybe have to adjust a bit on the levers if resistance is felt but by and large, full flow to each moves them just the right amount to bring them back level without a lot of finessing.
By the way, I have over 140 hours of use and 8 months of ownership with this backhoe prior to the mechanics screwing it up. I dont consider that a beginner and am quiet capable of using it to its fullest. I can pick up a cup sized rock with it by using the thumb and place it in a glass plate without breaking either the rock or the plate. I am not new to hydraulics or tractors having used them all my life, just not backhoes. I have also operated hydraulic cranes (cherry pickers to some of you) so I know a bit about finesse in movement of hydraulics, but like you said, when you are used to one type, (I guess mine is now excavator style) trying to use the other is really hard. I dont want to relearn this machine so I put it back like it was. I under stand why I had to shift the hoses from left to righ, but dont understand why I had to move the top to bottom and bottom to top. Just switching the control to different levers didnt work, but moving the hoses top to bottom and bottom to top made it back right.
/ B 26 backhoe running slower and slower #82
So when you swithed boom and dipper controls you moved a total of 4 hoses? That's how many I moved, 2 hoses per each control valve.
/ B 26 backhoe running slower and slower #83
No not split between two levers. The left lever works the dipper and the right works the boom which is just opposite the Kubota setup but it is the way I learned. The previous owner said it is set up to operate like a Case backhoe. I have never operated any backhoes before this one, so once I figured out what worked what it became a natural thing to do without really thinking about it. So when the mechanics screwed everything around, nothing would move in the direction that I wanted it to. Even when I got it in position to dig, if I pulled both levers like normal, it wouldnt dig, it would jump up (boom up too high, dipper too low etc, just wasnt coordinated in the movements like it should be.
With it the other way, I couldnt make it work to save my life. NOW, It still works the same way, push to extend the hoe and pull to bring it back but now it works correctly when digging in that after it is set in position, I pull both levers full back and the hoe comes back evenly with no erratic movements causing me to have to adjust boom up or down, kinda like the poster who asked about float position which it doesnt have by the way.
I dont know if it makes reading sense, but basically with it set up now, say that you are digging a ditch and want it 2 feet deep and you are attempting to take it down in 3" increments. Now I insert the hoe 3" below the grade, pull back on both levers full stop and the bucket stays at the predetermined hight, I just have to adjust the bucket level so it stays flat, as it comes closer to me it tends to curl up which is ok for digging in the beginning as you want the concave bottom contour. When you get to the depth that you want, you have to pull both levers back full and kind of bump the bucket control a bit as you come in toward the tractor so it stays flat and keeps the ditch bottom level.
It all depends on how you learned and the auto-response command our brains send, it is similar to driving a British car on a British road when you have always driven in America. You can relearn it but you have to relearn the whole schematic, shift with the left rather than the right, drive on the left rather than the right etc. Much of what you do when operating machinery, after you are familiar with it and with several hours under your belt, is automatic responses. You dont think about it consciously to turn the wheel to stay on your side of the road, it is autoresponse, so I just couldnt break the auto response impulse to pull one lever when my brain was telling me that the other one actually moved the darn boom or stick or whatever.
Ok I see what you're saying. So basically all the lever functions are the same, just on opposite sides. I'm not sure how that helped correct the erratic movements, but as they say, if it aint broke don't fix it. I definitely know what you're saying about once getting used to the controls a certain way, its very hard to relearn it any other way. Why would anyone even want to? I completely agree with setting it up the way you are comfortable, that leaves less room for error. Glad it all worked out for you.
Yes, I moved 4 hoses. At first I thought that I would just swap them back left side to right side which I did but it still worked backward from what I was used to. I thought heck maybe I mixed them up somehow and ended up putting the same ones back in the same spot, so I switched them back and still no luck. Then I was careful and switched them again but still didnt work right when digging. Working the levers everything went the right direction but it still didnt work the same. Finally it came to me in my sleep about maybe the swapped the top to bottom so I went out the next day swapped sides and this time put the left top hose on the bottom right valve and then swapped the right lever hoses the same way. Behold, it worked as I remembered.
/ B 26 backhoe running slower and slower #85
So I've been AWOL and just saw this thread Gary. I hope you've had luck getting this straight. I know NOTHING about hydraulics or backhoe operation other than the maybe 60 or so hours I operated that machine and I obviously didn't make any changes to the setup it had when I bought it. The original owner said he had our Kubota dealer swap those controls over because that's the way he was used to them. Man, I sure hope you get a solution (an preferably an inexpensive one at that)... Let us know.
I got it back to where I can work it, maybe it is the same. I used it to dig out some stumps and dig up a whole bunch of pine trees and stumps that we had cleared off the fence line right of way. Some of the tree we had sawn off a couple inches above ground level, so I went in and dug up all that I could find then cleared all the saw briars and weeds as far back into the woods as I could without damaging any more trees. Lots of dead wood laying around so I piled it all up so we have a pretty good fire break down the fence should something get loose in the woods. The BH is still slow and a lot weaker than when I got it, but I have decided to wait till warmer weather to do anything more with it. I did finally find the relief valve (you really need to take off the right tire and jack it way up in the air to get to it. I need to find another dealer that at least has the book on a B26 as Timberline didn't even have the service guidelines on it in their shop and finally just said, they are all the same so use the B 2630 model guidelines. I was asking about all the 200 hour service filters and such that I needed and that was all they could provide. When I got home, the B26 service intervals were the same so I suppose they were right, but when they called to ask what year it was, I knew they didn't have it in there system or they could have found the year via the serial numbers.
I think somehow that the Relief valve pressure got lower and lower over time for some reason and it is bypassing which is causing the oil to get hotter than normal also. I just need to find a dealer around here with some B26 expertise. I really haven't even been looking at it since I got it back to running right having finally got the hoses back in the right positions. Come spring, I will look at it more seriously.
/ B 26 backhoe running slower and slower #89
Gary,
got a question for you, this may seem way out in left field but have you checked your fuel filter for water or to see if it's stoped up? i scaned through all of this and dont see that you said anything about engine rpm's.
while spending the day at a buddy's digging a french drain i noticed my b3030 BH seemed to get weeker and weeker, i stoped digging and drove around the yard, it was then that i noticed i was unable to maintain higher rpm's. I went into full freak out mode thinking of all the worst things it could be. When i got home i walked in the house told my cfo the tractor was jacked up. i went into a rant and all she said was "ever put the filter thing on you forgot and left in the kitchen for a month?" I pulled a black fuel filter off that weighed 4 times as much as the new one, BH has worked great ever since.
/ B 26 backhoe running slower and slower #90
Just checking back in to see if you had checked the relief pressures and adjusted all the valves. They should all be equal.
My Case BH has restrictors in some circuits, and if your machine has them, and you switch hoses, the restrictors are not doing the job intended.
Gary,
Engine runs as it should, filter is clean. I just visualled it when I did the 200 hours service and decided it didn't need replacement. The only good thing with the Kubota plastic filters is that you can see if any thing is in them. All my fuel goes thru a 10 micron filter as it is pumped in. So far all my diesel equipment has never had a filter changed and still runs perfect with absolutely no evidence of water in the fuel. My tank is stored inside my boat shed so temperature fluctuations are minimal.
Yes, had to move 4 hoses from how Kubota shop had them. Basically it involved moving the hoses from the far right valve to the far left valve and switching the hose from top connection to the bottom and bottom hose to the top.
I haven't messed with the relief valve other than to remove the tire and see where it was. My dealer in Hot Springs didn't have any gauges or flow meters to sell and I really don't want to deal with them again on this machine. Its working although slow and weak but it still works if you are patient. I dug up a lot of stumps and pine trees with it a week or two ago. Its been bad weather here off and on since Christmas so I have been using the 1-2 days of good weather between storms for clean up activities. I will get my round-tuit out soon and make some calls to another dealer in Hope Ark. (Birthplace of President Clinton) and see if they know what a B26 is and maybe take it to them to check the flow and pressure.
I don't know if it has restrictors or not, but it has worked fine since I got it till just last couple months of use last year I noticed it moving a bit slower and not as much power plus the backhoe cylinders seemed to get pretty hot which to me indicates a lot of bypass at pressure resulting in oil heating up. They get hot enough to make your hand feel unpleasantly hot, not blistering hot, but very , very warm.
/ B 26 backhoe running slower and slower #95
You might be best off finding a good local hydraulic repair shop. Based on the age of the machine, I assume it's out of any extended warranty?
Any decent hydraulic shop could probably be able to track down the issue quickly, and at the least amount of cost to you.
/ B 26 backhoe running slower and slower #96
If I were you I'd pay close attention to what J J said about how the controls may be tied to a certain hose orientation from the factory. And until you commit to having someone test the flow and relief settings you'll never solve this problem. If you're possibly doing damage to your pump now by running the hoe at high fluid temps and possibly restricted flow, (clogged screen?), you may end up killing the pump and incurring big expenses in the long run.
Forget the first dealer- they ignored what you asked for and billed you to smash rocks on their lot for an hour?! AND they re-oriented your lines to how they were supposed to be from the factory- which now may make sense based on what J J said.
If it were mine I'd find a dealer or local hydraulic shop equipped and knowledgeable about tractor hoes and pay them to do the tests, NOW, not later, and figure out what is wrong. Short $ now- or long $ later.
This problem will not solve itself. Your hoe is trying to tell you something- you need to listen to it and fix it:thumbsup::2cents:
/ B 26 backhoe running slower and slower #97
another off the wall question. which also shows how smart my bota dealer is.
does your Bh have quick couplers that go straight to the tractor and not to aux pump? i only say this becuase my dealer could not believe my b3030 had quick couplers. the guy said something to the effect of "most of them go to an aux unit mounted to the back of the tractor" he said this set up had a internal filter.
spent the day on a medium sized cat track hoe, took me a couple hours to retrain my mind with the controls, totally different than my bota. i understand your frustration with the controls changed up. Man that thing was AWSOME, hyd. thumb made ripping trees out and tossing em through the air a blast.
/ B 26 backhoe running slower and slower #98
I know what you mean.
I occasionally do some work on a guy's property that I know, and he has a Case mini-ex, and man is that thing nice to operate. Amazing the power of a hoe that can rip through ground using a big 24" bucket. I try not to spend too much time on it, cause it makes me pretty bummed about my little backhoe when I jump back on it after being on that awesome little digging machine.
/ B 26 backhoe running slower and slower #99
note to self hyd. thumb a absolute must have on next tractor!!!!
/ B 26 backhoe running slower and slower #100
I didn't read the whole tread but I have a B26 and every now and then my does same thing then I remember the thumb valve sticks some times and I kick to get it centered and all goes back to normal.
