How to start a chainsaw
/ How to start a chainsaw #1
Don87
Elite Member
SW Pa.
Massey Ferguson GC2400
I received this in my e-mail. It was titled: How To Crank A Chainsaw.
/ How to start a chainsaw #2
thats funny i bet that was a add put out by planned perent hood.
/ How to start a chainsaw #3
Maybe a reproduction licensing exam:shocked:
/ How to start a chainsaw #4
I attended a chainsaw safety seminar and really except the direction of the blade, that is what the instructor said was the safe way to crank it. Put it between your legs and one hand on the top handle. I cant crank mine that way and have to use the drop and pull method which a lot of folks use, but is very dangerous to the lets if you loose it. Even then still sometimes it pulls the cord out of my hand. MY Husky sometimes seems like it is hydro-locked or something on the first pull and is very hard to pull, but it usually cranks on the 3-4 pull when cold and 1-2 when warm.
/ How to start a chainsaw #5
I attended a chainsaw safety seminar and really except the direction of the blade, that is what the instructor said was the safe way to crank it. Put it between your legs and one hand on the top handle. I cant crank mine that way and have to use the drop and pull method and still sometimes it pulls the cord out of my hand. MY Husky sometimes seems like it is hydrolocked or something and is very hard to pull, but it usually cranks on the 3-4 pull when cold and 1-2 when warm.
Gary my husky is same way if it's on compression strok it will jerk rope out of my hands sometimes, thats only way i have ever started a saw drop and pull.
/ How to start a chainsaw #6
Are you sure that email didn't come from your MIL?
/ How to start a chainsaw #7
That's only for trimming saws!:eek: After a dozen or more of these::drink::drink:
/ How to start a chainsaw #8
/ How to start a chainsaw #9
According to the chain saw safety guru, that is the way lots of folks do it and lot of folks get their legs cut. It isn't bad if I can start it with one hand on the top handle and it will start and idle, but if it is hot, I need to pull the throttle a bit so then it gets a bit iffy on the safety when I hold it by the rear handle.
/ How to start a chainsaw #10
This is a very dangerous way to start a chainsaw. You can easily punch yourself in the nose with a starter mishap. To thwart this danger, the chainsaw should be facing the other way with the powerhead just under the persons rear end. It is a much more natural move as well.
/ How to start a chainsaw #11
I know my stihl has a big flat part on the handle I think you're suppose to step down onto, at least thats what I use it for, dont see them on all chainsaws though.
/ How to start a chainsaw #12
I've got a couple of old Homelite Super EZ automatics made back in the late 60's or 70's that utilize a compression release that makes it much easier to pull...
I wish that more newer saws had those today...
/ How to start a chainsaw #15
One way I've learned are to set it on the ground, step on the handle, one hand on the top grip, one hand on the pull rope, and pull. The other way is to put the handle between your legs (not the bar), grab the top grip, and pull the rope with the other hand. And, of course, drop and pull.
/ How to start a chainsaw #17
TreeMonkey,
You may Not say "numb nuts idea" and not get in trouble. Perhaps you could say a "NO nuts idea." and get by with it... LOL
/ How to start a chainsaw #18
One of my BILs Homelite saws has a EZ pull rope that seems to tension a spring or something then it at some point turns the engine. The problem with that is you can pull and it doesn't do anything and then suddenly it releases is pent up energy and Vrooom, the engine turns over and sometimes starts when you think it is not doing anything. OK when you get used to it, but sure dangerous if you don't know the characteristics of the starting system.
/ How to start a chainsaw #20
Ya know, I better not take this for granted and state that I was kidding with this. This is one of the dumbest things I've seen anyone do with a chainsaw
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
110 GAL WATER TANK (A68842)
110 GAL WATER TANK...
2020 CATERPILLAR 316 FL EXCAVATOR (A65056)
2020 CATERPILLAR...
TEST YOUR BID BUTTON! (A65056)
TEST YOUR BID...
2006 UTILITY TRAILER MFG. CO. 48X102 SPREAD AXLE COMBO FLATBED (A67714)
2006 UTILITY...
2013 Ford Transit Connect Cargo Van (A66736)
2013 Ford Transit...
