Another source for PTO adapter?
/ Another source for PTO adapter? #1
HokieMS
Member
Buchanan Va
JD 4005
I tried to order one of the push-button release PTO adapter/extensions from Agri Supply. After going back and forth with customer service, I finally have confirmation that they won't receive another batch until after April. Does anyone have another source for these things? I got Pat's Easy Hitch, and need to extend my brush cutter shaft. Any help is much appreciated! I really don't want to buy a whole new shaft.
/ Another source for PTO adapter? #4
That one from Tractor Supply doesn't have the spring loaded locking pin. IIRC, it's for an old Ford tractor. I bought that type from Tractor Supply and it's basically a paperweight now. Never used it, in fact.
I can't determine if the other (from Belarus) has a locking pin...not from the picture anyway.
I'd suggest waiting until Agri-Supply has the adapter in stock.
/ Another source for PTO adapter? #5
The "belarus" one looks just like the one spyder linked to. It says its a quick release design. Dunno how it works. The one in the pic kenny linked too looks odd though, the male end looks like there are a lot more splines than just 6.
/ Another source for PTO adapter? #6
The one in the picture isn't the right one.. the description is correct though. 1 3/8 x 6 is standard in NA, female to male extension.
Sean
/ Another source for PTO adapter? #7
You have to look down on the Gripwel page and bring up "Reducer with pushbutton". Detail shows that some ar just size to = size extenders. :)
larry
1988 Kenworth W900 Day Cab (A62613)
1988 Kenworth W900...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2716SFL (A61567)
2716SFL (A61567)
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
