L2800 remotes?
/ L2800 remotes? #1
rdraper
Sharpsburg, Georgia
Kubota L2800HST
Hi everyone,
I am new to this. I own a Kubota L2800 and you all know that it does not come with rear remotes.
I have searched all over the net and have gotten some good ideas on how to install them. There are may different types of mounting options. I am pretty good at fabricating. I am not sure, yet, if I want to do a tnt, but that can come later. I am looking for some advise on what valve and connections I need. since I will probably have to order-I don't want to order too many times. I am probably going to go 2 spool. an FEL is already installed. Thanks for welcoming me aboard
/ L2800 remotes? #2
:welcome: Post your? on the Hydraulics forum and a guy named JJ should find it. He's the Guru of such.
/ L2800 remotes? #5
you would need a BL7033A and a L-7314 hose kit if you have a loader or a L-7315 without a loader. From parts you would need a 75541-68150 port plug and a 75541-68160 O-ring. They are available.
/ L2800 remotes? #7
Art are you hooking him into the hyd. outlet block, if not where are hooking him up at?
/ L2800 remotes? #8
The wholegoods numbers that I gave you go to the power beyond block, it is the factory set-up.
/ L2800 remotes?
Leejohn,
my plans are to tie into the PB of the loader valve to the inlet of the remote valve and back to the tank, with a PB from the remote to the PB port on the adapter plate on the side of the tractor. I just don't know what thread size I need to put in a "T" to the reservoir and to tie back into the PB port of the adapter plate. Thanks for the help, it is really appreciated. This is on a L2800HST with a L463 loader
/ L2800 remotes? #10
I don't know what size they are, but my guess would be 3/8 NPT at the block.
/ L2800 remotes? #11
Besides great info already received if you do TBN search there is a member here named "TEG" that a while back ago did a great step by step write up with pic's on L2800/L3400 remote add on.
Boone
/ L2800 remotes?
I ordered a 3 spool valve from Brian @ Fitrite. It is open center w/one float detent. Should have it a couple of days. Will get it installed and then figure out the plumbing. Probably after I get it hooked up, I will order a TNT kit. Brian has been great to work with. I will post later how it turns out. Thanks for all the help.
/ L2800 remotes?
:cool2: image.jpgimage.jpgimage.jpgH]image.jpgHi Murphy,
Just fyi, I got the remotes hooked up-finished today. I used a 3-spool valve I got from fit-rite. Turned out really nice, and it works! Thanks for the help
/ L2800 remotes? #15
Hi Murphy,
Pictures, no pictures, it never happened is the rule of thumb here on TBN. :rolleyes: ;) Actually it's nice for other people to see how it can be done. :cool:
/ L2800 remotes?
I took some pictures, not quite sure how to post them-a little help would be good
Volvo EC210CL Excavator (A64047)
Volvo EC210CL...
UNUSED RAYTREE REDM32 - 32" EXCAVATOR DRUM MULCHER (A62131)
UNUSED RAYTREE...
iDrive TDS-2010H...
2016 John Deere 318G Skid Steer Loader (A61166)
2016 John Deere...
1999 Sterling L7501 Dump Truck, VIN # 2FZHRLLB5XAA64093 (A61165)
1999 Sterling...
UNUSED ATS EJ 11000 ELEC.JACK (A62131)
UNUSED ATS EJ...
