mechanical clutch for subaru engines
  • Thread starter washita
  • Start date
   / mechanical clutch for subaru engines #1
W
washita
Guest
sent an e-mail to Continental engines yesterday to get specifications for a mechanical clutch they are building in- house to see if it would be applicable for the PT it looks promising will post more information as I receive it , unit is not very large judging by the pictures but I wonder about the price?
   / mechanical clutch for subaru engines #2
That would sure reduce the load on starting.
update ;Ron,
Thank you for your inquiry at Industrial Diesel Engines & Generators For Sale FPT Subaru Wisconsin Yanmar Hatz Parts - Continental Engines - Greenville, SC - Orlando, FL.
I am not sure what you are looking for. The clutch unit is part of the Power Trac unit. They can be reached at 276-988-6543.
I would need the complete engine specification, to provide pricing on replacement engine (i.e. EH722DS5150)
Best Regards,
Mike Cooper
Continental Engines
800-922-5632 ext 1846
864-235-4704 fax
60 Pelham Davis Circle 1016 West Church St
Greenville, SC 29615 Orlando, FL 32805
cid:image001.png@01CDD475.C97347D0
obviously I need to research this a little further
   / mechanical clutch for subaru engines #5
Good find.
They are coupling it with a reduction gear, but I would sure like just the clutch. I have been looking for an inline clutch like that, but the only v-twin clutches I have seen have had a pulley mounted to them.
Subaru EH72 Gear Reduction Clutch - Continental Engines - Greenville, SC - Orlando, FL
Edit:
Looking a little closer, I suspect that the plate above is just a mountingplate, and not the clutch. I think the clutch is resident as part of the reduction gear assembly, based upon the big lever that I assume operates the clutch throwout bearing to engage/disengage it. Don't think that whole thing could be sandwiched into our engne compartments.
   / mechanical clutch for subaru engines #6
It is too bad that they don't make centrifugal clutches as inline clutches, with a stub shaft instead of pulleys on it. You see those all over the place, and just about every riding lawnmower around seems to use them.
http://www.noramclutch.com/centrifugal-clutch/trilobe.html
edit: hmm, maybe something like this:
search ebay for centrifugal clutch coupling style, and you find a clutch that accepts 1" diameter keyed shafts from both sides.
This looks like a BLM clutch, but at least the ebay one of course has the wrong shaft sizes. It appears that you can spec the sizes at BLM, but I haven't found a vendor for them. Of course, this would require some sort of mounting bracket for the hydraulic pumps, since the current mounting bracket is not big enough around for a 5" clutch cylinder.
Anyone know the shaft diameter of the hydraulic pumps that PT installs?
http://www.blm-cm.com/prod1.asp\
Boston Gear also makes centrifugal coupling clutches. Anyone feel like being a guinea pig?
http://www.bostongear.com/products/clutch/chart-centrifugal.html
2014 BRENNER CRUDE TRAILER (A58214)
2014 BRENNER CRUDE...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A58214)
2012 TROXELL...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2008 FORD F-350 SUPER DUTY BUCKET TRUCK (A58214)
2008 FORD F-350...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
