L3700 hydraulic psi
/ L3700 hydraulic psi #1
Sammy3700
Red Springs, NC
Kubota L3700SU
Does anyone know right off what the max loader psi for the 3400,3700,3800 series tractors is? Bought a gage and quick coupler, going to check it tomorrow. Thanks
Thanks, I dug the book out and it is 2347. What would it hurt to have it at 2500?
/ L3700 hydraulic psi #5
Probably won't hurt anything.. I doubt you'll gain enough to really notice a difference though if it's set correctly to begin with. Mine was set right at 2250-2300 psi. I THINK the loader control has it's own relief valve, so if you increase that you still may not be able to get to 2500 if the main relief is set below that point.
Sean
Sean, There were 3 shims, all were the same thickness so I removed on and added on that checked .09 thicker and it is dead on 2500 at the loader control valve. At best it was 2200 before. Maybe all in my mind, I think it is better, it seemed like it was stronger when I ran it into a dirt pile I been playing with.
/ L3700 hydraulic psi #7
Which valve did you change the shim in? The one under the floorboards?
Sean
/ L3700 hydraulic psi #9
Only about 795 lbs of push force on the cyl x 2 = 1590 lbs
You should know what your pump max psi is rated at, and set it to about 50 to 100 psi below that.
Thanks J_J, Do you have any idea where I can find the pump max psi?
/ L3700 hydraulic psi #11
Your pump max pressure will be what ever the pump can deliver. 4-5000psi. The only relief on these tractors is in the loader valve on the GL's or in the PBY port on yours which is where the loader valve gets supplied from. I bumped mine 200 psi over factory spec and have no problems.
Thanks for the help. I thought I was doing it correctly.
UNUSED RAYTREE RMDM70 - 70" DISC MULCHER (A62131)
UNUSED RAYTREE...
208735 (A60430)
208735 (A60430)
APPROX. (15)-16' HDPE PIPE (A62131)
APPROX. (15)-16'...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
John Deere 612 2-Bottom Plow (A63116)
John Deere 612...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
