NEW TRACTOR --- (check inside for details)
/ NEW TRACTOR --- (check inside for details) #1
TSO
Elite Member
SouthEast Michigan
Massey 1652 HST Cab
So.... knowing that Kioti owners are a more tolerant and objective bunch than some other die-hard color fans.... thought you may appreciate this. I started shopping a few weeks ago to step up to a larger tractor. Started researching all the brands again (boy did I learn TOO MUCH about global production, and who really makes tractors now :confused2: ) and quickly ruled out Massey (Iseki), Deere, Yanmar (Cub), Mahindra, and Kubota due to the much higher pricing and/or lack of incentives. Finally, it came down to Kioti and LS, two "new kids on the block."
LS is part of LG Corp, they've been making tractors since the 70's. They are made in S Korea. They used to make the FarmTrac (Ford) tractors, and more recently have been making the New Holland Boomer series, as well as the Case (red) tractors. They also make Montana and McCormick tractors (although I heard that the contract was now closed with McCormick, and that Daedong was going to start building for them)... In '09 they decided to start selling their own "LS" branded tractors here to attempt to compete with, and take market-share away from, the big boys. Ironically, the Boomer-40 is nearly identical to the R4041, with the exception of stickers and the headlights are a bit different. NH puts their own loader (Rhino I think?) on the Boomer, where as LS uses their own. The funny thing about that is, the LS loader is actually much more capable than the one NH uses :eek: . NH also orders them built without certain "add-on" features like dual rear-remotes, which are standard on the LS. To top it off, NH jumps the price up roughly $3,000 for the same tractor! LOL... So, then I heard that there was some kind of fight happening between LS and CNH (Case-NH [Fiat]) which may be why LS decided to market their "blue" tractors under their own name now, in the US market. Subsequently, I heard that CNH may be leaving their contract with LS, and possibly returning to Shibaura, who used to build some of the older Ford/NH tractors & equip, and who still makes some of the larger stuff I believe. I also read something saying that Daedong bought some of (or all?) Shibaura. CRAZY GLOBAL BUSINESS!!!
So anyhow, it came down to the Kioti DS4510 (best dealer price $19,481), DK40SE ($20,500) --- and the LS R4041 ($19,200) (Shuttle Trans for all).
DS4510: Definitely a more rugged, less refined tractor than the others. It has good HP for the price, but I was not thrilled about the operators area, and didn't like the joystick location. I think it was only an 8 or 12 gear shuttle. The loader hydraulics seemed slow. I'm sure there is a place for this tractor, but for the minimal price jump, the DK is a better buy, although I like the "looks" of the DS series more.
DK40SE: Nice, open operators area. A little more "industrial" feeling than the LS... (just like the Kubota's feel more "industrial" than the Kioti). Everything felt well positioned, and I especially liked the tilt-column setup on the Kioti. That foot lever that easily rocked the whole column was very nice. The loader still felt a bit slow and unrefined compared with the LS. I also did not like the "view" looking over the loader arms. You'll notice in the pics below, how much taller the arms are on the Kioto vs the LS... much better visibility with the LS loader. Of course the trade-off is that the Kioti lifts about 11" higher (at the pins). The DK came stock with 1 rear-remote setup, telescoping arms, no rear work-light, no "installed" trailer wire connector. 12x12 Shuttle
LSR4041: Nice operators area, comfortable, but not quite as open as the Kioti when getting in. Dual hydraulic pumps which really seemed to speed up (and smooth out) the loader controls. (I drove 3-4 different Kioti's and 3 different LS', and the LS were consistently smoother with the loader). LS uses a Mitsubishi diesel. Obviously I can't comment on longevity yet, but the Mitsu sounds really smooth! I'd say 20+% less noise than the Kioti's. The LS comes stock with dual rear-remotes, a rear work light, 7-pin wire harness... telescoping arms, suspension seat (like the Kioti). It's a 16x16 Syncro shuttle. To be honest, there really wasn't much "driveability" difference between the LS and the DK.
Specs wise, the R4041 & DK40 are very close:
--------------------DK--------------R4041
HP -------------41 (34 pto)---------41 (35 pto)
3-pt lift -----------2493--------------2755
Loader (at pins)
Lift height---------107.8"-------------96.1"
full height lift------2761lbs-----------2500lbs
breakout----------3727lbs-----------4354lbs
Transmission------12x12 SS---------16x16 SS
DIMENSIONS
Length------------134.2"------------132.2"
Width--------------63.9"-------------55.9"
Wheelbase---------72.8"-------------69.2"
Weight w/o loader--3935lbs----------3813lbs
So, as you can see... they're both pretty close in specs. The DK is slightly larger, but weight is about the same. The DK lifts 261lbs more to full height, the R4041 has 600lbs more breakout force.
It really just came down to feel, options, and pricing. For $1000 less, the LS has dual remotes, a rear work light & trailer pin... (several hundred $$ to add those) ... and slightly smaller dimensions for a bit better maneuverability. They were both really nice tractors, and I don't I could have made a bad purchase getting either one.
I still have my CK20S. I'm going to put it up for sale, but in the mean-time, it will be the wife's tractor :cowgirl: --- We might just keep it as long as we can afford both, as there will be times with the size of the CK20S will come in handy.
PICS:
Bringing her home:
With the CK20S
Comparing the DK & LS (one of the dealerships I shopped carried both brands :thumbsup: (these were actually both HST which I test drove too, but preferred the Shuttle)
/ NEW TRACTOR --- (check inside for details) #2
It seems that you did the Research and bought the make and model that you wanted. Congratulations.
/ NEW TRACTOR --- (check inside for details) #3
I like the LS. My dealer carries them both now to, they dropped Landini after LS stopped making them and went with LS instead (they didn't want two different color Daedongs). When I recently asked my dealer which he prefered, he reluctantly (he did sell me a Kioti afterall) give the nod to LS. It was a no brainer for me since I wanted the cab and LS didn't have one (although I hear they're coming out soon).
Congrats, enjoy it. If it's on par with a DK, I know you will.
/ NEW TRACTOR --- (check inside for details) #6
Congratulations on your new machine, and you sure did your homework:thumbsup:
James K0UA
/ NEW TRACTOR --- (check inside for details) #7
Good job on research, I like the fold down ROPS better too.
/ NEW TRACTOR --- (check inside for details) #8
The Kioti folds too, but it folds at the base, so that means it is heavier to lift.
/ NEW TRACTOR --- (check inside for details) #9
That's why I like the LS ROPS better.
/ NEW TRACTOR --- (check inside for details) #10
Through research. If I had bought new I probably would have leaned toward the LS. That 600# of extra breakout would come in handy with the boulders we have around here, I have a Satoh with a 25hp 2 cyl Mitsu. It is a late 70's early early 80.s and besides normal engine maintenance I have only had to replace starter and glow plugs. Nice engines
/ NEW TRACTOR --- (check inside for details) #11
Nice tractor, very objective info. Thanks.
/ NEW TRACTOR --- (check inside for details) #12
I would be curious about any feedback on the dealer network for LS tractors.
My Kioti dealer switched to LS after Kioti insisted he buy an unaffordable inventory. Business was so slow he quit the tractor business completely.
My LS dealer is about 40 miles away, another one was 80. Definitely less convenient than my Kioti dealer, who is 15 miles. Kubota, Deere & Cub are all within 5 miles.
But, I have a feeling that LS dealers will b increasing once their name gets out a bit more. My dealer has been selling LS for 15+ years (FarmTrac, Montana). He is very happy working with them.
Sent from my Motorola Photon using TractorByNet for Android
/ NEW TRACTOR --- (check inside for details) #14
Nice new tractor. Congrats!
Curious what 'Toy' you are using to trailer your LS? Is is 6 or 8 cyl? And what do you use for braking on the tandem axle trailer?
Thanks, enjoy.
CM
Thanks, enjoy.
CM
2004 Sequoia 4.7L v8... not a powerhouse by any means (only 240hp/315tq)... but she does the job for now, and has been too good of a truck to get rid of (132k miles and running like a top). She gets a little soft in the rear, so I picked up a set of "Air Lift 1000" bags for the rear springs. They're not helping though, but that's because they're still sitting in the box in my barn :eek: (haven't gotten around to installing them yet).
I'm using a Blackbird brake controller from "Valley Industries." Works great on the the trailer, inexpensive (less than $100 with a direct-plug harness for your "tow package" equipped truck), easy to install... if you've never used one and have trailer brakes, get a controller!!!
/ NEW TRACTOR --- (check inside for details) #16
TCO,
Thanks for the info. I have an '011 Forerunner 6 cyl, and I tow a 27' dual axle boat trailer that had drums on both, with surge brakes. I'm in process of going to discs on all four. I believe the F-runner is equipped with tow pkg ready,(?) or something similar; is that what you mean by 'trailer brakes'?
(Not intending to hijack your thread...)
/ NEW TRACTOR --- (check inside for details) #17
Nice write up. Hope that LS works as good as it looks. What is the warranty?
Thanks, me too! 5 year (2 bumper to bumper, 3 additional powertrain).
TCO,
I just mean that if you have trailer brakes (brakes on your trailer's axles) you definitely should take advantage of them and use a trailer-brake controller to activate the brakes. Most vehicles (some of the new trucks notwithstanding) don't come with an integrated factory controller, so you have to purchase one separately.
Well, a bitter/sweet day came this weekend. I had my Kioti listed on Craigslist and someone came and offered me the right price. I had basically told myself that if I could sell it for "X" amount, then I would have to do it. Luckily for me, Kioti's are gaining value (like I assume the LS line will) and I sold it for $10,800. Not bad considering 1 year and 220 hours ago I paid $11,800 (plus tax) for it
So, I'm now a 1-woman guy again! I still think Kioti makes a great tractor, and I'll keep up with the Forum to see what's new.
Anyhow, here's a goodbye pic for my CK20. She'll be missed, she performed very well for me and moved a LOT of dirt! Nothing bad to say about her...
/ NEW TRACTOR --- (check inside for details) #20
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=306419"/>
You got a great price on that. It's always bittersweet to part with a friend.
2016 Ford F-450 Liftmoore 3200 1.5 Ton Crane Service Truck (A61573)
2016 Ford F-450...
2018 Utility FS2CHA 48ft. 36 Ton T/A Flatbed Trailer (A61573)
2018 Utility...
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61572)
2025 JMR 72in...
2013 Ford F-150 Ext. Cab Pickup Truck (A61573)
2013 Ford F-150...
2015 John Deere 8295R (A64119)
2015 John Deere...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
