fixing my disc.
   / fixing my disc. #1
Gary Fowler
Super Star Member
Bismarck Arkansas
2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
I guess I backed into too many trees because I have two bent axles on my disc. Today I decided to take it apart and straighten out the axles. I got my impact gun and took out the bolts holding the bearing carries for both rear gangs and lifted the 3PH up and neither gang fell. Looked under the bracket and the previous owner had welded all the bearing carriers to the gang support tubing. So first I tried to grind out the weld and got one on the inside but couldn't reach the other 3 welds even with a 9" blade, it was time to break out the oxy torch. I got one gang cut loose and decided it was time to disassemble it. I got all the parts off till I got to the bend and then the spacer spool wouldn't go by the bend. Well I did a little hammering on it and sure enough I was able to get it off, but it broke the end off the spacer (cast iron you know). I said what the heck, see if it will weld back. I put a bevel on one side and stuck both pieces back on the axle to assure alignment and put 2 passes of 7018 on it. It had a little magnetic arc blow and welded a little like metal with dirt on top of it, but it stuck together. I have it soaking in my 350F rod oven for a few hours then I will put it on the outside edge just in case it breaks, it will be easier to take off.
While I had it all apart, I looked at the bearing holders and all of them had at least one side torn about half way out. This is the little 1/16" thick plate with 4 bolts that holds the sealed bearings in the carrier. I got them all straightened and welded up the broken spot plus the rest of it. Each one has a pressure mark that is a slight scribe line where the press tool left a line around it when they put the lip on it. All of them break right in that press mark. The bearing are old old, so while I had it apart, I took my little needle bearing greaser and put in about 10 shots of grease in each bearing. I drilled a 1/16" hole in the steel seal, and pumped grease till it came out around the seal, rolled it several rounds and pumped more grease. It should be better than new now. I know it has more grease than new. Now to get it all back together then tackle the other gang.
Taking a lunch break now.
It will take me an hour to put away all the tools when finished. Two impact guns, 1/2 and3/4" drive, cutting torch, welding leads, drill, 2 extension cord, a 9" grinder, 4.5" with brush, 4.5 with grinder, drill motor, bits, 16#sledge, 4# shop hammer, pliers, chipping hammer, air chipping gun to remove the tab from axle nut, 3/4" combo wrench for backup on the carrier bolts, and a couple grease guns that I can think of off top of my head.
   / fixing my disc. #2
Got any pictures?
Remember the days when you had a helper to put away all the tools? :D
   / fixing my disc.
Yep, I started out as one of those and for a few year had some of my own when I broke out welding but somewhere along the way, the pipefitters got the helpers and the welder had to BORROW him for any of his jobs. Depending on how well the pipefitter treated his Welders, he would be lucky to get his bead ground and sometimes get their leads dragged to the new worksite, but more often than not, he had to drag them himself in the last 20 years or so and grind his tacks/root and brush off the weld slag. As a welding foreman supervising a crew of 15 welders, I would be lucky to get one helper to help me stage my welders and then only if they were supporting 20 or more fitters. Used to psss me off so bad that a fitter could spend a day making a fit that should have taken a couple of hours but then get to mouthing about the welder taking several hours to weld it up especially after having to accept a terrible fit up. And fitters could screw up manytimes and have to cut pipe etc to correct and not even take a butt chewing but if a welder busted a couple of xrays, then he was fired. Rant over.
I will see what pictures I can get of the spool. I didn't try to make it pretty, just to hold together till I could put it own.
   / fixing my disc.
I got no before pictures. I have to admire you guys that carry a camera around with you and take time to photograph everything. Anyway here is what the spool looks like after I did a quick and dirty weld on it. I beveled the edges on the long side and left it in the as broken condition on the hub side. There was one long crack running linear which I ground a groove in and welded it up also. Might have been more but I didn't take a lot of time with it. Figured if it broke, I could maybe get a replacement at TSC or Agrisupply. Sorry the camera didn't want to work very well this morning. They looked good in small size but get fuzzy when full size. Anyway, welding it was kinda like welding on potmetal as it just kinda dissolved as the rod passed over it. Main thing is it didn't crack when I put the impact to the axle nut.
   / fixing my disc. #5
Gary not to fire you up. But I use work a lot of refinery jobs. Been on some that would have over 200 pipe welders. I've seen it where the welders didn't do anything but weld, very unusual to see them use a torch. They would not drag welding leads, or even carry their buckets to the next weld. Very seldom would you see them use a grinder.
One time I was on a nuclear power plant job. Pipe welder who I had worked around before was in a 2-man repair crew. Welders would weld all day, x-ray crew would come in at night and shoot. Then the repair crew would fix any problems. This one welder had to go up on some scaffolding, about 80-feet to make a repair. No helper, so he was having to do his own grinding. I wasn't too far away from him but on the ground, I seen the superintendent coming, next thing I know a 9-inch grinder explodes on the ground right next to the superintendent! The sup about jumps out of his skin! Looks up and says, Orville why in the he!! did you do that?! Orville replies, because the mother f**ker doesn't work right. The sup just waves and walks away. I aways wanted to be a pipe welder!:D
Nice looking repair!:thumbsup: I know some of that stuff can be a nightmare to fix!
   / fixing my disc.
IMG_1168.JPGIMG_1169.JPGIMG_1171.JPGIMG_1172.JPGIMG_1173.JPGI finally finished all the welding, just have to put the gang back under the gang support. I found some 3/16" scrap plate that was just right to take up the slack in the outside support so the gang will not rock back and forth so much now. Even repaint the gang support.
Overhead weld is kinda crappy looking gorilla weld, ugly but strong. I just couldn't get my tri-focals to get in the right position to see it so it was welding blind practically and looking right into the afternoon sun so I couldn't even see the weld area prior to striking an arc.
The bearing holder photos, you can see the scratch in the metal from the press when they formed it which eventually caused them to split right at the line so I put a light bead around them all. Also drilled a small hole in the sealed bearings and using a little needle apparatus pumped them full of grease so now they should last another 20 years. The bearings were all tight but I could tell they were dry of grease. About 10 pumps per bearing with my pneumatic gun. I would pump it then roll them and pump some more till it started coming out on both sides of the grease seal.
   / fixing my disc. #8
Funny stories:) looks like you had a full day with that disc. Glad you got it fixed up!
   / fixing my disc. #9
I wear the progressive bifocal eyeglasses. I learned real fast I can not weld with them! It drives me crazy searching for the right spot to see. Now I just use dollar store reading glasses. They work fine if I can keep my head the same distance from the work.
I tried to teach myself how to Tig weld pipe like this picture, oh what a disaster!:eek: As the torch comes around the pipe, the distance changes, and I can't see.
Gary have you ever done any Tig welding like this?
   / fixing my disc.
it.
It been decades since I welded for a living, but yes, I did lots of TIG welding on pipe, walking the cup putting in the stringer in and feeding in the filler rod from inside the pipe on the bottom. I certified on just about any alloy used in refineries and chemical plants. I have TIG welded aluminum (my least favorite), Carbon Steel, all Chrome alloys from 1.25% to 12%, All 300 series Stainless Alloys, all Inconel alloys from 625-800, Titanium, Zirconium, Hastelloy, Carpenter 20 (dirtiest welding stuff you ever saw) and likely others that I cant think of right now. I also certified with most of those with TIG/SMAW, except the titanium and zirconium which can only be TIG welded. I did some MIG/FCAW welding but not a lot of it. I got my first welding supervisors job in 1975 but kept my hand in by certifying for next 10 years, then moved up to QC Manager and pretty much just watched it till 1990 when KBR wanted to invest in local community training at Long Beach City College. That required certification per ASME Section IX and B31.3 for all instructor, so I tested and passed and became an after work welding instructor at LBCC for 3 night per week @3 hours and 8 hours on Saturday. That was the last time I certified as a Pipe welder. Now my eyes require tri-focals, my neck has all the vertebrae fused except for the top 3 so I cant move my head much more than 10% of normal movement anymore. Now its pretty much what I can look straight at to see if I want to weld
   / fixing my disc. #11
Gary,
I understand where you are coming from, I was a Union pipefitter and sometime welder. Even ASME vessel certified. Started out in the refrigeration side of the trade but hated service work after about 15 years. As I had worked a lot of steel pipe on industrial ammonia plants I convinced the dispatcher to change my card to pipefitter. I never worked as a pipeliner and never saw a project where the welders were Prima-Donnas. The welders I fitted for took their certification ticket serious and would not let the fitter near the weld much less grind it. This was especially true where each weld was ided to the welder. I could fit for and keep 2-3 welders working when they did their own cleaning. I got them fitted and tacked and went to the next joint prep. I was never without a job, as soon as employers new I was on the bench the dispatcher got calls for me by name. Made a lot of foreman pay doing journryman work. Was foreman and gen foreman a lot. In 72 I left the trade for management.
Ron
   / fixing my disc. #12
WOW! You pipe welders sure get to work with a lot of different alloys. Way, way out of my league! When I go to the grand kids sports games I usually run into Navy shipyard welders, amazing the things they get to weld on! Remember one time talking to one of the high pressure pipe Tig welders, he said he would not accept a joint from the fitters if the joint varied more than .010"! In my line of work if you said that to a fitter, they would beat you within a inch of your life.:laughing:
   / fixing my disc.
I worked for Brown & Root, Inc. now called KBR for better part of 45 years. Welding procedures allowed for 1/32 mismatch (.031") so that is what we could hold the fitter too. Sometimes you just couldn't get that good and with welder foreman approval we would allow up to 1/16" formally but I have welded much more than that on fit ups to vessels and boilers when it just couldn't get any better. TIG and a wide gap can make a lot of hi-low almost invisible to the xrays.
I was telling about an experience back in 1975 of taking a test at the Celanese plant and lost the entry so I will try again. Celanese wouldn't let you use a grinder, only a file and wire brush allowed in the test booth. Even clean up of the test coupons was with a file. Anyway, B&R was doing a shutdown on an ethanol reformer(turned natural gas into ethanol alcohol) that the operator has literally melted the furnace tube in. All Inconel schedule 160 wall tubes that came from Washington state about ever 2-3 days we would get a truck load and when they were welded we laid under the furnace and napped so it was a gravy job. One day the supv. came and asked for volunteers to go take a stick rod test and no one volunteer (of course) so he volunteered me and an guy from Ok. we called Red. So we go up to the test area and meet the Celanese inspector, he gives us a wire brush and a slightly worn out file and some rods (6010 and 7018) and tells us to run a 6010 root, no hot pass with 6010. After the root we had to use 7018 for the rest of it. Well I was pretty much fed up with filing by the time I got the land filed down and not really caring whether I passed or not, I shot a slick 6010 downhill root pass, took a welding rod and scrapped off the slag, grabbed some 7018 3/32" rods and cranked the machine to about 160 amps and ran the next filler/ hot pass. I could only get about 1/2 of the rod burned before it melted out of the holder. I knocked off the slag with my file, cranked it down to about 125 amps and filled it and capped it off while Red was still trying to file out the slag lines in his. I went back to the furnace and checked in with my supv who was a bit surprised that I finished so quickly. He called the Celanese inspector to go look at it and he was happy with the visual. Xray was clean so I passed, so did Red but about 4 hours later than me which meant now we had to do stick rod. Well it turned out OK as the shutdown ended in about 2 more weeks but we continued to work there for 2 1/2 years and I got a lot of experience on different alloys including the titanium and zirconium, Hastelloy, Inconel, and all the other listed alloys. This plant made all kinds of chemicals and used just about every kind of alloy in existence so it was a really good place for me to learn a lot as I had only been pipe welding for about 3-4 years and I later got set up to welding foreman on that job and General Foreman on the next one and about 2 years later Welding Supt and my first overseas job in Saudi Arabia then to Venezuela for a couple years where I met my present wife. Oh, I got divorced while working in Saudi, perils of working overseas single status. For the next 15 years I worked stateside jobs moving from welding supv. to QC Manager in 1985. Then in 1990 went back overseas but took my wife with me on a 5 year job in Canada as Project Manager- Construction QC and stayed in the overseas job force for the next 12 years last 5 of which were single status so wife stayed home so she could play with the grandkids. All in all it worked out well for my early retirement which I had always wanted to retire by 62 and ended up retiring at 61 1/2 then went back for a 5 month job after I turned 62. As the godfather said, I'll make you an offer that you cant refuse so I didn't. I made $180K in those 5 months which was too irresistible to turn down.
   / fixing my disc.
I have one more tale of the Celanese job. A few days after passing that SMAW test, my supv. said go to test booth Celanese wants a heavy wall test weld made. So I go up and wait an hour or so for the inspector bring my test coupons and my file and wire brush. Eventually here he comes followed by a carry deck crane (DROTT) with 2 coupons about 12" long x about 10" in diameter which they use the crane to unload them. I have never before OR AFTER seen anything that thick. The test booths had sand for floor and I couldn't move the coupons, I found a piece of pipe that I could use for leverage to stand them up so I could file the landing down, as this was to be a TIG/SMAW test. Well after fitting these things for a couple hours I had them prepped but no way could I lift one, heck I couldn't even roll it in that sand. They were about 4" wall thickness and must have weighed 200# each. I finally got someone with a radio that I could call my supv on and request a cherry picker. Of course he asked me why I needed a picker for a welding test and when I told him I needed it to lift up the test coupon, he immediately says "hold on, I'll be right there" He was astounded to say the least and started laughing. The test was supposed to be heavy wall schedule 160 6" pipe which would have been about 1/2" thick not 4". It would have taken 100+# of welding rods to fill that other coupon and a couple or 3 days to do it.
   / fixing my disc. #15
You do have some great stories Gary!:thumbsup:
Almost 40-years ago I was working around a couple pipe welders who had just come off a job at the Port of Oakland CA assembling a container ship crane. Seems as I remember them saying it was 12 or 16-inch pipe with 2-inch wall thickness. Whole lot of welding for sure.:shocked:
   / fixing my disc.
I have had some experiences, like the time me and my whole staff were held hostage from 8am till 2 pm one day by the Nigerian workers who were irate over some money that they thought they were owed. Even though we had nothing to do with their pay as they worked for a contractor who worked for us an a lump sum contract, they caused us to lock our selves in the office and break out or bullet proof window covers (actually they were only bullet proof for 9mm pistol not AK 47 rifles which they were discharging all around us. The security folks finally got enough police to safely get us all away and back to camp around 2pm. As Fabrication shop manager I had to go back around 4 pm with our HR folks to listen to all 200 of them and their grievances and then make a report to the Senior Project Manager. He met with their tribal leaders and the workers representatives the next day and addressed the issues which they weren't happy with the answers and continued to strike but peacefully for the next week. All my staff got to stay in camp for 2 days while the senior management was working with them. All this followed a car bomb that had went off the previous week at the Governors mansion which caused us to have to evacuate the Warri Port Fabrication facility via crew boat which they had to move back 30 miles up river from the actual construction site to get us. Another very tense moment. When stuff like that happens and you are right in the middle of 4 million restless folks from 5 different tribes that 10 years previously went to war with each other and still harbored resentment big time, you don't know what to expect so you have to prepare for the worst. We had several instances with violent eruptions from the workers over really nothing that escalated into bullets fired and people dying so our security had to be on alert at all time. We were constantly in danger when on the road travelling the 13 KM from camp to the work site of being hijacked and possibly kidnapped. There was kidnappings just about every week of foreign nationals mostly for money and usually not more than $100K some times as little as $5K and then the hostage would be released unharmed. Only a couple of times were the hostages killed and we never found out much about those instances. All that is not too scary, what is scary is being out on a road alone and being stopped by a 12 year old kid with an AK 47 or an Uzi when he starts pointing his weapon around and demanding something that you have no idea what because you don't speak Arabic and don't know if you are going to be shot or robbed or if he just wants some water.
   / fixing my disc. #17
Wow, having to put up with all that:eek:, not sure the money is worth it!
Back when I was a superintendent one time I had a project manger who had worked in Mogadishu, I think it was for J.A. Jones. He had his family there with him. One night a local broke into their house, he had a machete! Dan said he was in the fight of his life, and a fight for his family's life.
Also worked for a guy who was in Libya when Gaddafi took over, I think that was for Brown & Root. He said one morning he was awaken by someone poking him in the head with a machine gun. All the construction workers were escorted to the border. That may not have been for Brown & Root, but I know he worked in Vietnam for Brown & Root.
   / fixing my disc.
One does take his chances when he leaves the USA border AND sometimes inside our border. Likely 9/11 took more USA lives than all the lives lost by workers in foreign countries not including war activities of course.
A fellow needs something to tell his great grandkids about. While it may be a little on the dangerous side, it beats telling them "well I went to work and came home everyday for 50 years from the same job at the same place". I could never do that and don't know how others stand working in the same location for all their careers. While I did stay with the same company most of the time (I did leave to work for others 2 times) it was usually 1-2 years at the same place and then move on. Only one lasted 5 years and it ended too soon as I loved working and living in Canada. Fishing was great and so were the people at least the ones in Western Canada where I was, cant speak to the eastern provinces. Most of the Canadians from Alberta didn't particularly care for the Ottawa bunch.
   / fixing my disc. #19
Gary I know what you mean, in my younger days I had a policy. I would not stay on a job more than 3-months. One year I had 13-W2s. One time I had 3-jobs in one week. For quite a few years my wife had no idea who I was working for. I would quit a job, and get another one on the way home. I would quit a good job close to home, because another contractor was working lots of hours somewhere else. The company I worked for the most in my life, I quit them 4-times over the years for one reason or the other. Most people don't understand how construction works.
   / fixing my disc.
I was a little like that when I was single. The first 3 years I worked with KBR, I never finished a job with a ROF, if they pssst me off, I was gone. More hours somewhere else, I was gone but then I settled down a little and stayed with the jobs till they were over or I got transferred by the company. B&R was pretty good in the 60's thru early 90's about keeping their folks a job, might not be where you wanted to go, but you had a job, then Halliburton stepped in and started dictating the policy and darned near killed the company. Finally they got out of our hair by spinning it off as a separate IPO and they are slowly making a come back in construction. For the last 15 years we have done mostly construction management which is where the big profits are but not many personnel needed and I was lucky to have a skill that is needed in this field and since most of our contracts for this service is outside the USA, that is where I worked for last 12 years of my career. Many or most of our construction staff went to work for S&B or Jacobs or Parsons. KBR is just now trying to get back on the bidders list for construction projects with Exxon, Shell, Chevron etc.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
4-Wheeel Hay Rake (A56438)
4-Wheeel Hay Rake...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
