Battery connected backwards
/ Battery connected backwards #1
KubotaSam
Gold Member
Maine
Kubota B2410, Kubota B7100Dt, Kubota B7100HST
I just bought my 3rd Kubota b7100. I seems like a great little tractor. I bought it from a dealer that took it in trade for a new Mahindra. Now here is my problem. I just got a chance to look it over at home today. I opened the hood and was looking it over when I noticed the battery cables were connected backwards. The cable to the starter solenoid was on the negative and the cable to the ground was on the positive. The tractor started and ran fine. I have only run it about 10 minutes since I got it. Here is what I am guessing happened.
1.Someone installed a totally dead battery backwards.
2. tried to start but battery dead.
3. boosted from a car or truck with the cables backwards on the tractor so it started.
4. The tractor charged the battery backwards so - is now +
I put a meter on the battery and the needle swings backwards. If I put the meter on - to + on the battery it reads 13.2 volts.
How do I fix this without buying a new battery? My idea is to put a load on the battery and drain it totally. Than try to charge it with the connections correct. What do you guys think? Has anyone ever been down this path? Seems I read about it but can't find anything.
/ Battery connected backwards #2
Until just now, I had no idea you could reverse-charge a 12 volt battery this way. Other Internet forums say that it happens when the battery goes dead flat and then is charged backwards. Presumably, to fix it, you would run the battery dead flat and charge it forwards. But bear in mind that deep discharging automotive-style starter batteries is pretty bad for them. If it was me, I would consider just letting it continue to run backwards until it died.
/ Battery connected backwards #3
I would discharge, connect properly, then recharge with a desulfating charger. I have no compelling reason to do so.
In many batteries, the negative side and positive side are designed differently from each other to account for special physical conditions in that part of the battery. Whether that matters or not, I don't know, but I'd want correct terminals/colors/markings on my system regardless, so keeping the old battery is just the fun/educational part of the project...so I'd keep the old one, and write on it the date of the re-reversal just to see how I came out.
/ Battery connected backwards #4
If it is working as is, just run it till it dies. Obviously it is working now and showing full charge.
/ Battery connected backwards #5
weird... never heard of such a thing...guess it can happen because you have the case proving the point...I think I'd not fix it until it breaks.
/ Battery connected backwards #6
hard to believe, get a new or used charged battery , hook it up the proper way before you short out all the wiring alternator starter and what not. Its not designed to run that way???
/ Battery connected backwards #7
I didn't know it was possible either. I would call the dealer I bought it from and see what his thoughts are. Aparently every thing is working ok but if it were mine I would want it right.
Bill
/ Battery connected backwards #8
For sure.
I have done reversing polarity on 12 junk batteries trying to get them to desulfate. When I just reversed charged them until after off the charger overnight they would read ZERO volt then recharged correctly I had some success (not worth the time if you need a good battery). The ones that I got to hold a reversed charge and test so so died HARD when I try to reflip them to OEM polarity. I think the write up is on this forum somewhere.
Again I would just use it as is as long as it starts OK then get a new battery.
/ Battery connected backwards #9
rayclar it is looked up properly. The polarity markings on the battery are just wrong now. :)
Until I wanted to buy a battery I would do NOTHING based on many hours of testing/experimenting with the process of reverse charging of lead acid batteries.
/ Battery connected backwards #10
I would contact the dealer and see what they'll do. If nothing at least you'll have some leverage if something should go wrong down the road.
I bought it really cheap. Basically sold as is. The dealer never touched it. He took it as a trade in and unloaded it at my house. I deal with them a lot I might mention it in passing to him but if he never got to work on the tractor I would not expect him to stand behind this. It is still a great tractor in really good condition for its age. I was just looking for info on reversing back the battery.
/ Battery connected backwards #12
Here's some information of reverse charging of a lead acid battery:
Battery Myth | Can a Battery
....So let me restate: The only way for a battery that has a positive charge, to reverse itself, is for the battery to be completely discharged, and then reversed charged. We have seen this happen a couple of times, and it would be considered the more common of these rare situations.
For all intents and purposes, the battery will be ruined. You could technically charge it up, negatively, and continue to use it, but your plates are designed with the positive plates being lead dioxide, and the negative being composed of a sponge lead, which would now be reversed. Because the reversed battery is no longer formatted correctly, it will only work to a limited degree.....
Sounds like a new battery might be a good choice in the near future.
Good luck,
Loren
/ Battery connected backwards #13
I would get a new battery as soon as possible before that one short's out inside and burn's stuff up.the plates will melt together and short out when your a mile away from anything to put the fire out. to me it's just not worth taking a chance like that over a $50 battery
/ Battery connected backwards #14
Check the manual it might be correct. I don't know that make of tractor but some autos are hooked up that way.
/ Battery connected backwards #15
Many may be too young to remember old Ford cars polarity. :)
/ Battery connected backwards #16
^^^^^^THIS!!!!!! Replace it now!! A new battery is $75 bucks, give or take. If the battery you have in the tractor now decides to burn up and take a few things with it, how much might it cost you to fix it then???? JMHO.
/ Battery connected backwards #17
I'm not that familiar with kubotas but some older JDs have a positive ground. Check it out first.
/ Battery connected backwards #18
Ditto...it's the dealer's fault here. don-ohio:2cents:
/ Battery connected backwards #19
Listen to this guy! Your battery is shot, even if it still works. Get it out of the tractor and use it as a core!
One thing he forgot to mention: is it worth it if it leaks acid all over your tractor after it blows up?
/ Battery connected backwards #20
Not to hijack but, I once installed a pair of new C cells in something or other and the device did no work so using my volt meter I checked the cells and discovered that one cell was somehow built reverse. Never did figure out how that could happen.
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNGK26K97G305720 (A65563)
2007 Chevrolet...
2011 MACLTT  150 BBL ALUMINUM VACUUM TRAILER (A65643)
2011 MACLTT 150...
New/Unused AGROTK YC-26G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
New/Unused Wolverine 48in Mini Combination Bucket (A65583)
New/Unused...
2006 GMC T7 4X2 S/A SERVICE TRUCK (A66091)
2006 GMC T7 4X2...
Mini Universal Wheel Barrow (A65640)
Mini Universal...
