Concrete molds?
   / Concrete molds? #1
jymbee
Upstate, NY
Massey 1652, 1949 Farmall H
I'd like to experiment making such things as small sitting benches, table tops, etc. using concrete. Anyone have experience with using concrete molds sold for this purpose?
   / Concrete molds? #2
I've never used a pre-made mold, but I made a mold out of melamine for my countertop project.
   / Concrete molds? #3
I've made a few using basically and sand box...if you are going to cast items exposed to the elements and you are going to mix your own concrete be sure to use an "air entraining" agent to prevent freeze-thaw fractures etc...
   / Concrete molds?
Very impressive! What techniques did you use to come up with what appears to be a pretty unique surface??
   / Concrete molds?
Thanks-- good advice. Not quite sure what you're describing with "sand box". (?)
   / Concrete molds? #6
There are countless cool things you can do with a mold. In this case, i applied some glass fragments to look like red salmon, and after the mold came off i ground the surface away to expose the aggregate stones. There is also some blue pigment that i added to the mix.
   / Concrete molds? #7
I have border ones an stepping stone molds i bought off ebay, The plastic versions will last a while but not for a long time I normally duct tape the mold before I use to to make it last longer. Its better to get the thickest mold that you can. I keep a can of spray oil (cooking ie pam) to spray the mold and then pour in.
   / Concrete molds? #9
Important to use a vibrator to get the air out of the mold. You can use anything really. ( insert joke here ) Just place it against the mold after you have poured, and have a little bit extra ready to pour in when the air escapes.
   / Concrete molds? #10
I used a plastic mold to make a patio years ago. One bag to each mold, and it worked. Now it is under another 3 feet of earth. But I have made a couple of molds using hardwood with waxed paper on the inside of the mold to make it realease, Hinges on the corners.
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A51039)
2015 Ottawa Yard...
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
2019 Fontaine Traverse HT T/A 48ft Loyboy Trailer (A49461)
2019 Fontaine...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A51039)
2019 Ford F550 4x4...
