BX25 With Chipper attached to PTO
   / BX25 With Chipper attached to PTO #11
Yes, this is the procedure in the manual, but I find that you can just pop the seat up without having to actually rotate it into the rear/BH position. Just a little quicker to put back into the normal position when you want/need to reposition the machine.
I went a step further and installed a "Chipper Bypass" toggle switch just under the right front of the seat, so it's partially concealed. I just ran a SPST switch(two terminal) in parallel with the safety switch (that keeps the PTO from working unless the seat is turned around on a BX.) Now instead of having to sit or reverse the seat to use the chipper, I just flip the switch.
"parallel" means that the new switch shares to same wires as the safety switch, just a Y connection to each existing wire so either switch, the original seat safety switch or the bypass will each do the same thing.
   / BX25 With Chipper attached to PTO #12
I just buckle the seatbelt over the seat on my b2320
   / BX25 With Chipper attached to PTO #13
And I went a step further than that, unplugged the seat switch and ran a jumper wire from one wire to the other, bypassing the switch permanently.
   / BX25 With Chipper attached to PTO #14
I did too but didn't want to admit it in case the safety police were on patrol - but it seems all clear...
Thanks a lot all you responders; many ideas there. When I get the chipper back on I will try them all and decide what works for me. As to the manual, I have both the Operator and Shop manuals and they are totally silent on that subject. The seat switches definetily make the BX25 idiot proof for those who would probably get tied up in the PTO. As I use the chipper in a business; the Stae L & I will make me fashion a guard for the PTO. Thinking that over also.
Ron
2019 Ford F-550 Knapheide Service Truck (A48081)
2019 Ford F-550...
UNUSED Clear Multi-Wall Polycarbonate Panels (A50860)
UNUSED Clear...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2005 Ford Escape XLS SUV (A48082)
2005 Ford Escape...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2014 Chrysler 200 Touring Sedan (A48082)
2014 Chrysler 200...
