New Member with BX2360 mower deck question
/ New Member with BX2360 mower deck question #1
JIMK56
CHARLESTON, WV
bx2360
I added a snow blade and need to lock mower deck in upper position when plowing snow. I have never had much luck with the knob adjustment and have not gotten much help from the user manual. Can anyone please explain the best way to lock it while plowing snow? Thanks for your help!
/ New Member with BX2360 mower deck question #2
Welcome to TBN :)
I moved your thread to the Kubota Owning/Operating forum.
/ New Member with BX2360 mower deck question #3
Lift all the way to the very highest using the 3pt lever, then turn the deck height adjustment knob at your feet to "Top". Will lock the mower in place, but allow up and down movement of the 3pt.
/ New Member with BX2360 mower deck question #4
Thats the way its suppose to work, but you can find a lot of threads on here where people can't get it to lock in the top postiion. Mine won't, but it cuts well and cuts level so I hate to mess with it. I take my deck off in the winter and I am able to get the mower lift arms to lock in the top postition.
/ New Member with BX2360 mower deck question #5
There is an adjustment for that behind the left rear tire. It should be in your manual and there is at least one thread here on it. I had the same problem on my new BX25 but this cured it in about 10 minutes.
Sent from my iPad using TractorByNet
/ New Member with BX2360 mower deck question #6
I believe that I would take it off for the winter if at all possible. Even locked up you may have trouble high centering on snow. High centering means loss of traction which is pretty important when plowing.
/ New Member with BX2360 mower deck question #7
just to be clear - are you able to rotate the height knob in one direction AFTER the 3 pt is lifted all the way? be sure the flow control knob is open too. You should be able to turn knob to top and leave it there to prevent the MMM deck arms from going down.
/ New Member with BX2360 mower deck question #8
Why not take the deck off for winter use? It is very easy to take off. It sounds like you may need to adjust the cutting height knob for the top position.
/ New Member with BX2360 mower deck question #9
Mine wouldn't lock on TOP either when I first got the machine. A small adjustment fixed it. I took the deck off for the winter as well . Much easier to snow blow without it dragging in the snow and sticking off to the sides.
/ New Member with BX2360 mower deck question #10
If you are lifting the 3pt all the way but the knob will not click into the Top position, it likely does need the small adjustment others have mentioned here. It is pretty common to need to make this adjustment. I've copied and pasted the best/simplest instruction for the adjustment that I've seen.
(Compliments to Harry at BXpanded.com)
The heght adjustment "Top" position holds the deck in the fully raised position regardless of the 3 point hitch position. Raise the deck completely and turn the height adjustment to "Top". If the knob won't turn to "Top", do the following:
Looking at the rear of the tractor, just inside the left rear tire is a linkage that controls the lift. There will be a gold colored bolt that faces rearward. Loosen the lock nut on the bolt and screw the bolt in one turn. Raise the mmm all the way and see if the knob will turn to the "Top" position. If not, turn the bolt another turn and try again. It shouldn't take more than a few turns of the bolt unless something else is out of adjustment.
(BTW, I agree that taking the MMM off for winter plowing is the way to go.)
2025 GPS Trailers (A56857)
2025 GPS Trailers...
2018 FORD TRANSIT 350 SERVICE VAN (A59823)
2018 FORD TRANSIT...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2017 Ford F-150...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
2015 Ford Fusion Sedan (A59231)
2015 Ford Fusion...
