John Deere 4200 4x4
/ John Deere 4200 4x4 #1
kcaver
kentucky
john deere 4200/L130
I have a JD 4200 tractor and it sounds like a constant air leak, like come out of a tire, but it's not any tire. It only happens when the tractor is running and it loses power just going up an incline. It's a hydrostatic model about the year 2000 or 2001. I have run my hands all around the tubes, trying to feel any air movement.
Thanks
Suzanne
/ John Deere 4200 4x4 #2
Thanks
Suzanne
front or back?
/ John Deere 4200 4x4 #3
May be a gasket on the motor.Losing power,any of the tires look like they are going down.?If checking tires ,mix up a spray bottle with water and dish detergent and spray around the tires ,look for bubbles.
/ John Deere 4200 4x4 #4
First thing that comes to mind is to check the exhaust manifold for cracks or bad gaskets. Or the fuel cap for a plugged breather.
sounds like it is coming from the back
It sounds like it is coming from the back
It only makes the noise when the tractor is running. No sound of air when it is off.
/ John Deere 4200 4x4 #8
Exhaust leak or intake air leak at the filter or manifold.
Get a tube, (2-3 feet long) put one end to your ear, use the other end to listen at various spots. Be very careful of the moving belts, fan, etc. Tie your hair back, button loose sleeves, take off rings, chains & bracelets... You are working around moving parts. Don't get sucked in.
/ John Deere 4200 4x4 #9
Does it have the Power Beyond option installed, like to power a backhoe or log splitter? I suspect what you are hearing is the pressure relief valve activating indicating blocked hydraulic flow.
That sounds like a good idea, I will give hat a try, because when the engine is running it is hard to pin point.
Thanks
If that's the case how do I fix that?
/ John Deere 4200 4x4 #12
Do not use your hands to find leaks! You might encounter a hydraulic leak that could pierce/inject oil thru the skin.
More info coming soon (A64557)
More info coming...
2017 CHEVROLET TAHOE SUV (A66091)
2017 CHEVROLET...
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
CAT 963 4-in-1 Bucket (A68134)
CAT 963 4-in-1...
2014 Ford Escape AWD SUV (A66738)
2014 Ford Escape...
