npalen
Elite Member
I understand that the plastic will prevent moisture transfer but what exactly am I trying to prevent by using it?
. I have only five words to say--DO WHAT GARY FOWLER SAID!!!!
Personally,GARY FOWLER I'm confident you know what you're talking about, especially seeing that you're familiar with the correct industry terminology. "PLACING CONCRETE" is the proper term....because if you're "POURING CONCRETE" which is what the majority "DO" it's had too much water added. The installer will often add water on site so it's easier to push around. But the extra water lowers the PSI of the mix and takes longer to sit up. There's no point in making it harder than it needs to be. Knowing that water is so often added on site is why I recommended 5000 psi concrete.
As long as we are going to get hung up on proper terminology, instead of results, I have never seen concrete "sit up"
Two things. First concrete is porous and will wick up moisture from the ground and deposit it in the form of "sweat" on the surface when the outside temperature changes from very cold to warm and moist. The concrete holds both heat and cold(lack of heat technically as there is no such thing as cold ) and takes a while to stabilize so warm moist air condenses on the surface and it sweats. A moisture barrier will keep some of this down. Second, it acts as a separator so the new concrete doesn't bond to the old concrete and allows the new slab to float.I understand that the plastic will prevent moisture transfer but what exactly am I trying to prevent by using it?
