M8540/M9540 540/1000 rpm PTO Conversion install
/ M8540/M9540 540/1000 rpm PTO Conversion install #1
ovrszd
Epic Contributor
Missouri
Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
I decided to add the PTO conversion to my M9540 so I contacted Messick's and ordered the kit. The cost was $1156 plus sales tax and they shipped it free. Surprisingly, it arrived on a pallet. Didn't think about it being that big.
Here's what you get.
From start, which was driving the tractor up on blocks, to finish which was driving the tractor off the blocks, it took me one hour and twenty minutes. Fifteen minutes of that was spent draining and refilling oil. So the mechanical part of the install was an hour. I check twice and do once so that time could be cut in half by someone better organized than me.
There's nothing technical about this install and no requirement for special tools. A 17mm socket removes all the bolts and nuts holding the case on. 13mm wrench removes and installs the PTO covers. A pair of vise-grips removes and installs the two studs in the tractor housing. A gasket scraper cleans the mounting surface. Tube of silicone sealer for a gasket. Pair of pliers to remove the snap ring and change PTO shafts. Pretty simple. Draining and filling the oil is the worst part to me.
Surprisingly, again, the gear box is assembled. That simplified this install tremendously. I thought I would have to put it all together. The instructions also included directions in assembly of the gear box. They must have figured the average Joe Tractor Owner couldn't figure it out. Inside this assembled gear box are all the mechanisms to allow PTO speed changes simply by swapping the output shafts.
They also included a new drawbar. The instructions say the new longer bar is needed to maintain the proper horizontal distance between the PTO shaft and the hitch pin hole in the drawbar. This is because the new gearbox moves the PTO shaft rearward about two inches.
To begin with the transmission/hydraulic fluid must be drained. This is a PITA because it holds 16 gallons of oil. A real pain to drain into 5 gallon buckets. I backed the rear tires of the tractor up onto 6" blocks and then let the air out of the front tires to tilt the tractor forward as much as possible. I then drained out of the side mounted drain plug. I removed all the oil that would drain out of that plug which was around 12 gallons. In hindsight I think 10 gallons would have been enough to let me remove the rear cover without losing fluid on the floor. After the fluid was drained I removed the PTO shaft cover and then the 8 bolts and 2 stud nuts that hold the rear PTO cover on. I used a small pry bar to break the seal and allow me to pull the cover off. The PTO shaft and propeller shaft come off with the cover.
Once the rear cover is removed you looking into the bowels of the beast, literally. In these pictures you can see the diff lock collar and shifting fork on the left side. When you step on the diff lock pedal you move the collar to the right. The four pins in the collar engage the left side spider gear to the ring gear carrier which essentially makes both wheels spin together. When you release the pedal and force is removed, the collar is pushed back to the unlock position by springs. Anyone who has had a colonoscopy can relate to these pictures.... ;)
Here are some comparisons of the mechanism that's removed and the dual speed mechanism that is installed.
Because the gearbox is thicker due to having two sets of gears, the propeller shaft has to be replaced with the new shorter shaft. They tried to put all of the additional thickness inside the tractor housing that they could. Couldn't move it any farther forward because it would hit the ring gear.
I'm an instruction reading freak. I spent fifteen minutes going over and over the four pages of instructions before I started. This saved me a considerable amount of unnecessary work. For example, the first page of instructions goes thru the process of changing out the pins that hold the lower end of the 3pt lift cylinders. Then the last sentence of that page says "if tractor is equipped with 3pt assist lift cylinders previously, disregard all instructions above". Not sure what that's all about. But the pins DO NOT need to be changed.
The instructions also talk about the two straight pins that are between the tractor case and the PTO gearbox. It says to install those pins into the gearbox case before installation. My pins stayed in the tractor housing and I left them there. The bag of hardware that came with the kit only had one pin so good thing mine were reuseable. There are also two studs, one on each side, about halfway up. The factory studs have to be removed and the new longer studs installed that are provided. So when you are ready to install you have two studs, one on each side, and two pins, one lower left corner and one upper right corner sticking out of the tractor housing. The long studs make the install a lot easier. It's a place to hang the gearbox on without getting against the sealing surface and smearing all the sealer off.
There is no gasket involved in this install. The instructions say to use sylicone sealer which I did. I use the red type. It is heat resistant. Not sure it's needed in this application but it's what I use on everything. I have better luck with it than the blue type. I didn't take any photos of this process but I put a liberally large bead of sealer on the tractor housing, surrounding all the bolt holes and pins.
The gearbox assembly weighs somewhere around 50lbs. As I said above, the studs make this a lot easier. Once on the studs I pushed it against the short pins. I couldn't push the gearbox all the way against the tractor housing because the pins fit the holes so tight. I had to gently use the bolts to draw it all together. I turn of the bolt on one side, then a turn of the bolt on the other side until I had it tight together. Sealer squished out everywhere, which gave me a good feeling knowing I had a tight seal. There are 8 bolts and two studs with nuts holding the gearbox on.
I tried to take a couple photos of the difference in appearance before and after this conversion. You'll notice it moved everything farther rearward. You also have to use a different PTO cover that is provided.
In the end I had some pieces left over from the kit. Basically the lift cylinder pins and their hardware. Plus all the old parts that were removed and/or not reused. When the weather warms a bit I'll hitch up my recently acquired 1000 rpm brush cutter and try it out. :thumbsup:
/ M8540/M9540 540/1000 rpm PTO Conversion install #2
Excellent write up! Really enjoyed the pics as well!
Thanks for the compliment/comment. It was much easier than I expected. Expensive,,,,, but easy....
P.S. Ported MS441???? Not enough power for ya or what??? :laughing:
/ M8540/M9540 540/1000 rpm PTO Conversion install #4
Might have been easy for you, but sure doesn't look like it would be easy for some of the rest of us; congratulations on a job well done.:thumbsup:
Larry, it was easier than I expected because I thought I'd have to assemble the gearbox, lucked out there. Still a huge PITA to drain the oil.
On another topic, I bought a used JD 1008 1000rpm mounted cutter a couple weeks ago. Hooked it up before I had the PTO done just to see how the tractor liked it. Had my loader off. Sure glad I built a weight rack!!! Had 630lbs of weights on the front and could have used a couple more!!!
/ M8540/M9540 540/1000 rpm PTO Conversion install #6
Haha....yeah well.....:D
After having ported my last few saws, including an MS660, I can't bring myself to run a stock saw. They just rip!! It pulls a 28" bar buried in hardwood with authority now.
I can only imagine!!!! I have a 361, 250 and old 018. Love Stihl saws. In fact,,,, I'm not sure anyone else makes a chainsaw beyond Stihl..... ;)
/ M8540/M9540 540/1000 rpm PTO Conversion install #8
The JD1008 looks similar to the Woods 121 we used for years and no way would we use it without the FEL on our Case CX80, never put it on our Kubota and bought a pull type.
/ M8540/M9540 540/1000 rpm PTO Conversion install #9
The 361 is a fantastic saw! Responds very well to a muffler mod and carb retune.
/ M8540/M9540 540/1000 rpm PTO Conversion install #10
cool thanks for the write up. I did not realize it was basically a plug and play kit from the parts diagrams. It definitely look like its worth the money though based on what they give you. I think its funny that your old 3 pt shield has the same dent in it that mine does from the top link hitting it. I bent mine with the Plow.
/ M8540/M9540 540/1000 rpm PTO Conversion install #11
I llove my 361 never thought about doing any muffler work on though. If i want more power i just pickup the 660 of which i have seriously considered putting the older 066 muffler on. If only the 660 weighed as much as the 361
/ M8540/M9540 540/1000 rpm PTO Conversion install #12
nice job on your tractor on aside note the 3pt lift assist cylinders on the 70,85,95 an so on id LIKE TO ADD THEM TO MY 7040SUD can it be done they dont list them on the kubota site on build my kubota for my tractor the 7040 doesnt lift enough for me any ideas on that i was told it cant be added to my tractor
/ M8540/M9540 540/1000 rpm PTO Conversion install #13
Install looks good, nice writeup.
You'll like the 1008, we have a pull-type 1008 and it is a brute of a cutter. Dad bought it new in '87 and we've cut thousands of acres with it since. IIRC an 85 PTO hp tractor is what Deere considers minimum based on weight (like the 6cyl 2950,) so I bet you will need a lot of front ballast.
Be sure to post some pics of it in action when you get it hooked up.
/ M8540/M9540 540/1000 rpm PTO Conversion install #14
Ovrsizd, you sure put togher a good post! Thanks, the $1150 price when you first talked obout ordering it seemed like a lot. The "kit" is much more than I had envisioned and seems like a very fair deal for what is supplied. (I was thinking that you just switched shafts as equiped from the factory)
I bent mine backing the brush cutter over the edge of a bank. :)
My only experience with this chassis is my 12 speed 9540 which comes with the larger lift 3pt. I never thought about any coming without the cylinders??? Probably going to require a trip to a dealer to ask that question.
Neil Messick's is on here frequently, PM him with the details of your questions and he'll steer you right, no charge.
Oh, you know me,,, I'll certainly post pictures.
I was shopping for a Bush Hog 3210 or 2010 when I found this cutter. The going price for a Bush Hog was $4000-$6500. I found this cutter at a JD dealer for $1800. It did not have stump jumper pans on it. I thought something dreadful had to be wrong with it. Finally I decided I could do a lot of repairs at that price. It had a new PTO shaft on it, almost new blades, solid gearboxes with no leaks, 4 tail wheels. I rebuilt the slip clutch and added pans which cost me $320. It appears the cutter has spent it's life doing finish mowing. Very few pimples in the deck. Sitting on concrete the blades were set 4" high. I won't cut anywhere near that low, I set them at 6". So, I'm anxious for Summer to get here so I can see what I got.
Do you have any idea what this cutter weighs?? I can't find any technical data on it anywhere. I'll end up using 850lbs of front weights. I cut a lot in confined areas and can't run with my loader installed.
I agree, I thought I'd change out all the internals of the original case cover, never even thought about the drawbar thing. As I said before, I'm glad it came assembled, the instructions talks about pressing on gears, etc, etc.
In the end, I guess the biggest gain is the ability to run either speed. If this just strictly converted to 1000rpm I'd say it was too expensive. In a matter of less than a minute I can go from running my 1000rpm cutter to running my 540rpm post hole auger. :thumbsup:
/ M8540/M9540 540/1000 rpm PTO Conversion install #19
The integral model weighs 2006lbs, and that is with only two tail wheels. I have a manual right here if you need any other specs or info.
/ M8540/M9540 540/1000 rpm PTO Conversion install #20
We run a Bush Hog 3008, 2 pt hitch with our M8540 and the best thing about the mower is the tires! The dealer ordered it with (used) airplane tires and those stay on top and roll easily over everything. In 5 years of hard use the tires have not been punctured.
Those tires I would suggest to anyone with a big, heavy mower behind.
Looks like the 1000rpm conversion kit is a winner, too!
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
New/Unused Landhonor Leaf Blower (A61166)
New/Unused...
1991 INGERSOLL RAND DD-24 SMOOTH DBL DRUM ROLLER (A62129)
1991 INGERSOLL...
2008 International 4300 Altec LRV60-E70 70ft Forestry Bucket Truck (A61568)
2008 International...
2010 Freightliner M2 106 Forestry Grapple Truck (A61568)
2010 Freightliner...
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
