737mech
/ 737mech #1
737mech
Royse City, Texas
Ford 1920
Good afternoon!
Have a Ford model 1920 with a 1708 loader. Can this unit pick up round bales? Also, have tech questions if someone has experience or knowlage with this tractor. Thanks. Have a blessed day!!!
/ 737mech #2
:welcome:
/ 737mech #5
Welcome to the forum. I am sure it could pick up a bale but there is alot a variables.
/ 737mech #6
Good afternoon!
Greetings and welcome to TBN.
Assuming your tires are liquid filled to ballast the FIL and your using a spear attachment. You should have no problem with round bales. Or are you using a three point hitch spear.
/ 737mech
Good Morning All!
I bought this tractor used and it just needs some TLC. But, I did try a bucket spike and it tried to lift them. However, I'm thinking if I used a regular attachment in place of the bucket (thus moving the CG toward the tractor) I would have better luck. This leads to the next item of discussion....the hydraulics bleed down. Both the loader and the 3-point. I'm going to assume that the majority of that is connections (QD's) and o-rings. I have a 3-point hay spear and it works great. I used my mower as ballast till I had the first few bales on the ground. The tractor itself handled everything well. Just hydraulic issues. Before I bought the tractor I asked the wife if we were going to feed round bales and the answer was "we shouldn't need to".........That'll teach me.......
Thanks guys. Have a blessed day!
2016 Dodge Charger Sedan (A61569)
2016 Dodge Charger...
UNUSED WOLVERINE TD-13-36R STUMP DIGGER (A62131)
UNUSED WOLVERINE...
20 Yard Dumper (A61166)
20 Yard Dumper...
2021 Salford 550-30 Cultivator (A63116)
2021 Salford...
2013 Ford F-250 Ext. Cab Pickup Truck (A61568)
2013 Ford F-250...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
