Homemade chute rotator perfected
   / Homemade chute rotator perfected #11
My set up is similar for rotation, works slick and has served me well for over 5 years now.
Another mod I made was to fabricate plastic chute guides to replace the metal ones that were factory installed as the metal ones created too much friction.
I also made a large plastic washer for the chute to sit on as metal sliding on metal is not exactly as smooth as I wanted.
I simply now add a few squirts of oil from time to time and my chute never freezes up.
To make your reverser switch yo need a spring loaded, center off DPDT switch.
You solder 2 opposite corners with a lead going to the motor and the other 2 corners also going to the motor.
The 2 center leads (lugs) are your power in.
Any good toggle switch rated at 10 amps or more will do just fine. Use 16 gauge wire and I fused with 15 amp fuse.
OK, now I understand what you're doing.
Are you switching the motor current with those switches or is there a relay box somewhere??
Just those switches. The winches regularly draw around 5 amps,...in this application of course.
16 gauge seems a little light to me but I guess it would work.
Yeah my chute already rides in plastic grooves. It's a Pronvost and it came that way.
   / Homemade chute rotator perfected #14
If you're only using 5 amps then you might be interested in one of these. I put one on my chute rotator because the switches were difficult to operate with gloves on. This thing is a whole lot easier and would do all four directions in your setup.
JOYSTICK | AllElectronics.com
2019 Cummins L9N 8.9L 6-cylinder Turbo Diesel Engine (A55851)
2019 Cummins L9N...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
UNUSED FUTURE FT 72 PRO 72" HYD MULCHER (A57193)
UNUSED FUTURE FT...
2020 John Deere 1025R MFWD Compact Tractor (A57024)
2020 John Deere...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A57024)
GMC 3500 Extended...
