Backhoe Hose connection on gc2410tlb
   / Hose connection on gc2410tlb #1
porjoh
peterborough ontario
MF GC2410TLB
Does anyone know if the blue and yellow hoses get connected and the red hose capped on a massey glc2410tlb.
Mmm will not raise and I think this is the problem.
Thanks
   / Hose connection on gc2410tlb #2
This is how they should be hooked up (just as you posted) when the BH is off.
Thanks much appreciated.
The problem must be something else -I will call the dealer.
   / Hose connection on gc2410tlb #4
don't trust the colors of the zip ties. Be sure the hose that ends close to the back of the tractor, is the one thats capped. the other 2 hook together. if your loader is working fine & your engine isn't laboring the wrong return is hooked. Have you had your backhoe off before with everything working? I've seen them come factory with the male & female ends on the wrong hoses not allowing proper connection.
   / Hose connection on gc2410tlb #5
x2
when I first used my MMM ,with the BH on the tractor,the mower would not lift.the dealer had the lines labeled wrong.
As MFRED mentioned,the line coming from the rear housing,is the one that needs to be capped.
   / Hose connection on gc2410tlb #6
x2
x3-same happened to me.
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A56857)
2017 JLG Skytrak...
JMR 96in Forklift Safety Basket (A56857)
JMR 96in Forklift...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JOHN DEERE 850K LGP (A58216)
JOHN DEERE 850K...
