Broken Glass Door
/ Broken Glass Door #1
bhub
Woodstock, GA
John Deere Gator
I have a 3320 Tractor with glass cab. Haven't driven in about 2 weeks and yesterday noticed the right hand glass door shattered into a million peices. I have ruled out being hit by bullet or rock. Has anyone had this to occur?
/ Broken Glass Door #2
I've heard of guys breaking the doors driving with them open and the bouncing of the tractor causes them to break.
Real hot weather has caused truck topper windows to break.
/ Broken Glass Door #3
Tempered glass is funny stuff. Strong as the dickens on the surface, but very prone to failure at the edges. Look for anything in the door frame that may have given undue force to the edges of the glass. Anything harder than rubber is suspect.
Joe
/ Broken Glass Door #4
Have a Mahindra 8560. A day after first delivery, while sitting in a closed barn, the right rear glass just shattered after it was started up. Several months later the driver side door glass blew out. No vandalism, rocks, bullets or other, 75% of glass outside of the tractor.
/ Broken Glass Door #5
We had it happen twice on our Case; left side both times and never figured out why.
/ Broken Glass Door #6
Had it happen to this one. Backed into a tree, it put a very slight bend in the frame at the edge where the arrow is, but didn't break the glass, that is glued to the other side of the frame. About a month later after a cold night, I drove it out of the shop and parked it with the sun shinning on that side. The top half was closed. A couple of minutes later the glass shattered.
/ Broken Glass Door #7
Has happened me twice so far, in a 5420. Once because the door was open, and the second time I was on the road and it was really windy and they have not fixed the door correctly because it didn't go into the closed position, it just swings open once in a while and the door swung open and hit a sign.:mad:
/ Broken Glass Door #8
On the 8560 was the problem ever corrected. I just bought a Mahindra 8560 and also having that problem.
/ Broken Glass Door #9
Have seen birds smash tractor windows .
/ Broken Glass Door #10
As regards the Mahindra owners, I had a glass break on my 4510 but it was hit by a tree. The glass replacement cost was $139, not bad, the shipping was $309. Bad.
Anything that can hit or flex the glass or put pressure on a small area could lead to breakage.
/ Broken Glass Door #11
something as small as a needle head, of what should be a nice clean flat surface, and glass will break given just enough pressure / vibration.
experience with diy custom aquariums and diy stands for myself have made me learn the hard way. if there is a slight bow or turning were the glass lays down, "crack" goes the glass. smooth level and perfectly all the way around the edges are needed.
/ Broken Glass Door #12
got a Mahindra 4510 right side door glass broken out were can I get glass with out spending 800,00 dollars ?
/ Broken Glass Door #13
/ Broken Glass Door #14
Could u tell me were y got your glass . My door glass broke on my 4510 to.
/ Broken Glass Door #15
The left door on a 6920 shattered, glass went mostly outward. Driver had just got out , closed the door and was walking away and bang, he looked around and the door was in the proverbial million pieces. There was no apparent reason for the breakage.
/ Broken Glass Door #16
You know - that's a lot of broken glass for what little exposure here, so far. Surprised that some form of plastic isn't used.
/ Broken Glass Door #17
Could I ask were u got your glass I broke mine on my way 4510 and dealer wants 700. For it thanks dave
/ Broken Glass Door #18
Used the dealer and nz$559.00
/ Broken Glass Door #19
The driver side door glass has broken spontaneously twice on my Mahindra 8560. I figured out that this happens due to the door switch putting too much pressure directly on the glass.
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
2014 KAWASAKI KAF400B (A66091)
2014 KAWASAKI...
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
E-Z Trail 300-bushel Gravity Wagon (A66408)
E-Z Trail...
1500-gallon Poly Tank (A66408)
1500-gallon Poly...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
