Ballast Box Build
   / Ballast Box Build #11
The bench vice looks have some history..one tough vice.
   / Ballast Box Build
So your going to have the tube going thru from one side for a long hitch pin right.
Yes, I will have a long hitch pinch to hold the hitch into the receiver. I will have to fab some sort of lock to keep the pin from sliding out when in use.
   / Ballast Box Build
following thread need to build one myself as for the tombstone welder .. I would of bought a used mig first since i bought the mig have not even touched the tombstone its like 9 years already ....
Jeff
Well...I am not supposed to weld period. Have a medical stimulator implant that interferes with the pain receptors. The leads rest against the spinal cord. Stray voltage apparently is not advisable...:)
Had this thing ten years...you know - the heck with it. I am going to take it slow, keep the ground between me and the rod - and live life a bit :).
That said, I don't have the flexibility to contort to weird welding positions - so I am limited to "bench" type welding. So - I went cheap in the welder - knowing it wasn't going to get much use.
   / Ballast Box Build
Do you have a sketch of your plan?
I do - but it's in my head :)
Bought a cat II drawbar from TSC. The square tubing for the receiver will weld into the drawbar, which will be orientated on its edge. Two pieces of angle will run up from the drawbar to form the 3 pt connection.
I will also run angle iron on an angle from the vertical angle iron to the horizontal steel tubing. Once the concrete is poured, I doubt if this angle is necessary - but it will provide structure before and during the pour.
   / Ballast Box Build #15
When I keep plans in my head I lay pages down in some corner then forget where I put them!! Are you welding up sheet metal sides or sticking that drawbar through a plastic juice barrel?
   / Ballast Box Build
The vise is a good Wilton one. When the old Allis Chalmers plant closed down, they auctioned off what was left. I got several workbenches, and this one had the Wilton vise. Think I bought this one for $50.
The table is approx 4 x 10'. I built a maple top on one end for woodworking, and put a 3/8" steel plate on the other end for metal working. Love my bench. Will get some pictures of it later.
   / Ballast Box Build
No, I use to be a carpenter in my younger days. So I have some 3/4 ply that I will form up for the pour. I have a quart of Kubota orange that will spruce up the concrete next spring. Gonna let this thing cure for quite a while before painting.
   / Ballast Box Build #18
I'm thinking about making one with a black plastic barrel. I'm going to fill it about two thirds full and let the top link connection come out the side near the top of the concrete. The space left on top will be for tow chains etc. and the screw on top will keep things dry.
   / Ballast Box Build #19
Are you welding DC reverse polarity? Works best for me.
   / Ballast Box Build #20
Well to lock a hitch pin in place you can make a 90 degree handle at the end of your pin, and mount a hook on the out side of your box thin all you do to lock the pin is rotate the handle of the of pin into the hook. Should work just fine.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
2017 Ford Explorer XLT SUV (A48082)
2017 Ford Explorer...
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
2005 International 8600 Hydro Vac Truck (A50860)
2005 International...
UNUSED 48 in. Oversized Bolt Cutters (A50860)
UNUSED 48 in...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
