Good morning!!!!
/ Good morning!!!! #7,681
I reduced my Cholesterol a lot and low enough on the LDL (less than 100) not to take a statin IF I HAD NOT HAD THAT HEART ATTACK. But now the lower limit for people with confirmed heat disease is less than 70 and that is less than my body normally makes (hereditary) so I am still taking a low dose statin. My LDL is hovering around 60. The Doctors really don't care about the HDL because it acts as the garbage truck and if there is less trash to remove it is lower and more trash to remove it is higher.
However, the statin is the only med I'm taking and my wife who is also on the diet also takes no meds at all. Our weight is in the correct normal BMI range for our height and has stayed constant without counting calories and eating as much as we want. 22 mo post heart attack and no problems and I'm doing physically as much as before. Blood test levels are all in the normal range - including protein - I take no supplements.
There is one more aspect to this diet I have not mastered and will try but this will be hard. All unprocessed foods. I think I can get there now that I don't miss the animal products and oils. Last weekend I learned how to do it that made it seem easy without feeling completely deprived. I might get off statins yet....
Congratulations on your numbers Don....outstanding....your diet is working and you are obviously now enjoying the true taste of food without the need to juice it up with all of the poisons....You are winning and the proof is in the numbers....You Da Man !!!!!!
/ Good morning!!!! #7,682
Thanks a lot Don I really appreciate the tips and links. Lancaster is a pretty conservative place and it is a lot harder to find this kind of stuff out.
Chris
/ Good morning!!!! #7,683
36 degrees and an interesting phenomenon called thundersnow. Thunder, lightning and snow. Don't recall ever experiencing this.
/ Good morning!!!! #7,684
69F here at 1:45PM. I quit at 1pm, so only got the 1 wall up, but the second is all cut and ready to nail together. Have to go into town and order my metal roofing.
David Sent from my iPad using TractorByNet
/ Good morning!!!! #7,685
Oops, duplicate
/ Good morning!!!! #7,686
I am so jealous... Thunder snow is awesome...
Be well,
David
/ Good morning!!!! #7,687
Thanks Bob and Chris,
You know that 5K I mentioned that I did last weekend racing against vegans at the conference. Well I did a little research and now I don't feel so bad that so many in my age group beat me. Here are two of the 50+ guys that I could not catch.
#1 Kyle Heffner - Last years winner in his age group at the Boston Marathon and on the 1980 U.S. Olympic team in the marathon.
#2 Robert Cheeke - his web site says it all.....
http://www.veganbodybuilding.org/robertcheeketraining.htm
It's so much easier racing meat eaters in my age group, at least I can place.:D
/ Good morning!!!! #7,688
Had that winter of 1973 in northeastern NC, thn in Feb. '79 here in MD. Both times it was snowing so hard you old just see the flash against the white.
/ Good morning!!!! #7,689
Good evening all. 28F this morning, 42F was the high and sunny (yellow UFO was spotted).
No precip in forecast butt still hav the roller-coaster temps, Monday's high is about 25F.
/ Good morning!!!! #7,691
I can recall having thunder-snows in Missouri during certain phases of El Nino or was it La Nina? We would get from 6 ti 18 in. snow out those turkeys. Otherwise typical snow amount would be closer to 1-2 inches.
/ Good morning!!!! #7,692
Let see mundane chores update :(. Clean fireplace aches and glass doors, go in to work for 3 hour (billable tine) and build fire and take wife out to dinner. Was going to go where granddaughter worked but they gave her the night off (too slow). Did I put you all to sleep? :rolleyes: :confused:
/ Good morning!!!! #7,693
Mundane chores, somebody said....? I just deleted several of the posts I had made on that stupid "Rt-polo" thread...lowering the count there so this thread can pass it sooner. Where is my "attaboy"....????
BTW, what the heck are FIREPLACE ACHES....and BILLABLE TINE.....??????!!!!! Go get some sleep yourself....:laughing:
/ Good morning!!!! #7,694
Atta boy jd! Question? Now that you are divorced should you eat more meat or more yellow watermellon? (hint - "greger"):D
That reminds me I need to clear out that sand garden by the spring for the summer watermellon crop, looks like there might be a run on the yellows.
/ Good morning!!!! #7,695
2013-01-18, 0410
1 degree right now....16 will be the high.
Friday...I love Fridays!
/ Good morning!!!! #7,696
Currently 27, high of 33 with partly cloudy skies.
/ Good morning!!!! #7,697
12 degrees here and calling for it to zoom right up into the low twenties….Hey it is Friday and that means the wifey and I will go out for lunch…
/ Good morning!!!! #7,698
31 and clear. it started snowing about 4pm, and it was heavy and started to accumulate, but in the end, the temp wavered too much and we mostly got rain, it might be nasty freezing rain out there, not sure yet...
No sledding today...:thumbsdown:
Back to work...
Be well all,
David
/ Good morning!!!! #7,699
Mossflower, Same wet snow over here with only an inch actually sticking because of the rain. But we did have thunder and lightning with the snow last night. Because it's only 28 degrees with icy spots, they've closed schools.
/ Good morning!!!! #7,700
Nippy -0F clear sky,low 20's today :( Sat & Sun mid 30's :)
Hard to believe better than half way thru January.
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
Metal Transport Rack (A59228)
Metal Transport...
2013 Ford Edge Limited AWD SUV (A59231)
2013 Ford Edge...
Kubota RTV X900 (A53317)
Kubota RTV X900...
2017 BX2680 Sub Compact Utility Tractor (A61306)
2017 BX2680 Sub...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
