New Attachment
/ New Attachment #21
why not rotate the bracket 90 degrees, eliminating the stress on the hoses as well?
OR 45 degrees would maybe work better. As you say photos are deceiving so if it works as is then it is good. Just be carefull with those ties to keep everything out of the way. I had put some tyraps, and rope on some hoses on my FEL to keep them away from the tire when turning. Well one day the ties loosened up or broke and while backing up and turning sharp the front tire grabbed two of the hoses and ripped them from the quick connect. Luckily all it broke was two male couplings. Now I have rerouted all of them to be out of the way without ties holding them.
/ New Attachment #22
If your tractor is still under warranty, I would advise to check warranty policies on the tractor- loader with LS. In the event of a failure, as a result of use of that bucket. Just an idea.
/ New Attachment
Why would I worry about the warranty using a stump bucket?? No difference in that and a root grapple. You can do just as much damage with the standard bucket, if not used properly. I'm not afraid to work my machine, I just try and use common sense!!
/ New Attachment #24
why would you have a failure with that bucket?? my dealer sold me a 4 in 1 bucket for mine.
can't wait to see how it works was looking at them also ......
(there is way to many toys to buy for this tractor ...lol)
Jeff
/ New Attachment
Stump bucket was delivered today, and looks good and stout. Can't wait to get it in the dirt! It should perform well. I would think you would be more likely to do damage with the standard bucket, as you would with this one. All of the digging force is concentrated right in the center of the loader, as it should be. Unlike using the wide bucket and having the pressure exerted on a corner. That's how loaders get racked. I'll be willing to bet I'll get the back end off the ground, though !!!
/ New Attachment #26
Some pics of the new stump bucket in action would be good!
/ New Attachment
Well, as luck would have it, the weather was nasty this morning. I did go unload my new stump bucket, and could not resist the urge to just dig something up. I was so wet everywhere it was ridiculous. I dig manage to dig up a few small trees, and a few small stumps. I think its going to work out fine. Can't wait to really try it out when it dries up a bit.
Here are a couple quick pics. The small saplings only take one stab, and pop right out!
/ New Attachment #28
What diameter is the 'sapling' in the first picture? Looks like its between 4 and 6 inches?
/ New Attachment #30
Yep, that's about what it was. One scoop took care of that one!
That says it all right there - I NEED one!!!
Guess I better get the tractor first though....
/ New Attachment #31
I'm thinking about getting one for the farm to pull out the palms but I'm afraid ill tear up the root ball....
Magnus, you still haven't gotten the tractor... What's up...
/ New Attachment #32
That looks like a backhoe on a FEL. With exception of having a swing side to side, I bet it works just as well as a backhoe for removing trees. Only con would be being able to get your tractor in position which would be easier with a backhoe, but about $7000 more expensive. While it is wet is the best time to dig out trees, they come out so much easier.
/ New Attachment
First thing I did after unloading was to head back into the field to try and puck about a 6" oak out. Stabbed it in and lifted, and noticed my front wheels sinking into the soft ground. Figured it was time to back out of there, and leave that one for another day!
/ New Attachment #34
Oaks have a large root ball. Best to stab it from all sides working your way around the base till you have stabbed thru all the roots then on your final stab, try to lift it. Get as close to the trunk as the beast will cut thru the roots to avoid having such a large amount of mud and roots. A pressure washer is best for removing that mud /dirt from the root ball if you plan to burn it.
/ New Attachment #35
I have been interested in a stump bucket. Look forward to you review / videos. Looks like you have sandy soil compared to our red clay. It is amazing how well a tree will root into the clay.
/ New Attachment #36
IMG_1156.JPGIMG_1154.jpgAmazing how they root into anything. Recently I hooked a rather large pine tree with the back of my disc and pulled it down rather easily. This was a tree over 12" in diameter and 40+ feet tall. When it snapped over, it left about 1/4th of the tree trunk sticking up about 2 feet so I was going to dig it up with the backhoe. This is what I found under the stump. The tree was about the same size as the one in the second photo in the foreground.
CATERPILLAR D8T CRAWLER DOZER (A64279)
CATERPILLAR D8T...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
1984 Mack MS250P Fuel Truck, VIN # VG6M114B1EB080951 (A65563)
1984 Mack MS250P...
ATS 13,000lb Electric Winch (A62679)
ATS 13,000lb...
