B6000E
/ B6000E #1
94BULLITT
Super Member
USA
yes
I found a B6000E on craigslist with a Woods MMM for a good price but it needs a block. The guys says it had water in the oil and the block is cracked. Before I check into it more where would I find an engine or block for it? I think it has a ZL600 engine. I found some B6000's on auction time from $2500 on up to 4k or more. Are these tractors really worth that much?
/ B6000E #2
Roger have you checked when the tractor was made? ( 1973-77 ) You might only find parts at junk yards but I see them around alot. Also it has a counter-clockwise PTO shaft. If you can find a engine it sure would be fun to fix up. You just have to get it cheap because it might take awhile to get all the parts together.
/ B6000E
I looked online at Wengers and did not see anything. I guess I could call them for the heck of it. I don't know of any other tractor salvage yards. I am going to do some more searching. I thought it would be fun too fix up and have to mess around with. I really don't need it. According to Tractor data it is on 3' x 6' so it would not take up much space. I saw the PTO was counter clockwise rotation. I just found they do not have a water pump, I don't like that.
/ B6000E #4
The B7100 or 7200 doesn't have a water pump eather, seems to work ok. I know I don't like it as well. You are kind of like me when it comes to messing around. I like making all the stuff for my tractors and fix up small tractors. When it comes to the big ones I do, but sure don't want to get hurt.
/ B6000E
I saw that engine is also used in a marine application so I guess it would be fairly reliable.
/ B6000E #6
I just seen you and I have the same tractors. My BX is the 2660.
/ B6000E #8
How do you like your 4240? I like mine just fine, until I get up in the woods then it seems so long. I also had to splite mine to fix the seal for the input shaft. It was done under warranty, but they didn't do a good job at it.
/ B6000E
I love it and the BX too! I have not used it in the woods too much yet. I had a Bobcat CT235 previously and I think the 4240 will has a better turning radius even though it is bigger. If I get in a tight area sometimes I take the bucket off to make it shorter.
/ B6000E #10
Well one more thing to do on here then out of here. We well have to chat again. Lee
/ B6000E #12
6000 was a tough no-frills tractor...had one. Very overbuilt. 6000E is 2WD version. If I were going to re-do one, I'd hold out for 4WD (6000). 4WD made huge difference in capability. Lack of water pump not that uncommon on older tractors...called thermo-syphon cooling...works on convection (hot water rises) to achieve circulation. Never had problem w/mine...just keep radiator clean and fan belt tight...
As for parts, another possible source is Western KY Salvage (West Kentucky Tractor Parts)
/ B6000E
I don't think I am going to get it. It looks like it would be really easy to put way more money in it than what it would be worth. I re do like the the looks of the B6000D, they are pretty tough looking little tractors.
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2016 Peterbilt 389 Day Cab (A62613)
2016 Peterbilt 389...
121A (A63745)
121A (A63745)
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
New/Unused ATS 60 Gallon Two Stage Air Compressor (A65583)
New/Unused ATS 60...
