Snow New snow plow project for your viewing pleasure
   / New snow plow project for your viewing pleasure #1
tomf
Nebraska
Kubota B2400 HST
Last week, I bought a Western 60125 seven foot snow plow to attach to my B2400. Attached are some photos of the plow and the mount I made. I plan to prime, paint, and add hydraulics. Cost of the plow was $300.
   / New snow plow project for your viewing pleasure #2
Are you worried about racking the frame? There seems to be a lot of metal out front that if you angle will produce some good torques? Just curious.
   / New snow plow project for your viewing pleasure #3
Sounds like you got a good deal on that plow. I suggest that we all keep buying snow removal equipment: this way it's guaranteed not to snow.
I'm not too concerned. I've done some research and it doesn't seem to be a big problem. Here's a link that shows a B2400 with a 6.5 Myers. I'ts the seventh post. http://www.tractorbynet.com/forums/kioti-owning-operating/257547-snow-plows-attach-fel.html I'm also going to add a cushion valve to the hydraulics to decrease the likely-hood over-torquing the tractor. I'll post pictures once I get it installed. I currently have a small 5 foot blade rigidly attached and haven't had a problem. See below. No cushion valve on it. If you have any suggestions I'd be glad to hear them.
   / New snow plow project for your viewing pleasure #5
I built mine similar to yours but my tractor weights 7,000lbs.I think you should shorten up,put your ears behind the cross member.Thats a lot of plow/leverage on a B2400.
   / New snow plow project for your viewing pleasure #6
I built mine similar to yours but my tractor weights 7,000lbs.I think you should shorten up,put your ears behind the cross member.Thats a lot of plow/leverage on a B2400.Looks like you could shorten by 15-18".
   / New snow plow project for your viewing pleasure #7
I'd say you didn't buy that plow, you stole it for $300.00! Good find on your part. Years ago I was able to buy a Meyer ST-84 for $250.00 from where I worked. It was used one or two years and then left outside in the weeds to rust because for some reason the building & grounds guys didn't like it. I took it home, cleaned it up, made power angle & lift brackets, made a push frame & used it on my Oliver 77. I used it about 18 winters. I still have it but since getting my B3030 HSDCC in 2007 it is now my second line of snow defense. It will out-plow that B3030 by a wide margin because it is a much bigger tractor but sitting in that warm cab is just soooo nice!
   / New snow plow project for your viewing pleasure #8
This is my set up on my 7510. I didn't want to have to remove the bucket, so I have pins on the inside... I plow, drop the plow, and then use to bucket to stack it up... (I also have a second property that i can only use the bucket at).
After the first season, I cut 6" off the width and removes the 3/4 " x 4" steel wear edge to reduce the weight. Made a hugh difference..
I also only use slight angle in heavy / deep snow, so as not to rack it...
Also I no longer use a chain, but have a steel pipe that conncets the plow to the upper bucket area, so I use the FEL float mode, and can use down pressure if I want.
It use to be a western plow from a toyota, I paid $200
   / New snow plow project for your viewing pleasure #9
Nice work. I am concerned that a 7ft plow is big for your tractor. I only have a 7' on the L4240. You can always make it smaller if you have to.
   / New snow plow project for your viewing pleasure #10
Nice neet/clean fab job.
I consider guest of sort where you pin to plow frame ears,plowing at 45 degree put stress on one ear.
2019 Peterbilt 520 Trash Truck (A55973)
2019 Peterbilt 520...
Sellick S80 (A53317)
2010 Chevrolet Tahoe SUV (A56859)
2010 Chevrolet...
Takeuchi TB216 (A53317)
Takeuchi TB216...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
Mower King ECSSCT72 Quick Attach 72" Trencher (A56469)
Mower King...
