Generator and electricity flow
/ Generator and electricity flow #1
PAGUY
Gold Member
southeastern PA
Kubota BX2200, Gravely mower
I have a friend who told me his nephew was advised that because he has a 220 plug on his generator it was possible for him to power up his house through the dryer plug. He was told to make sure to turn off the main in the circuit panel before hooking up a wire with a male plug on each end and he would be able to power his house.
Now my friend figures he can do a similar hook up using the outdoor plug (110 volt) by turning off the main and most of the circuit breakers in the panel except the refrigerators (2) and the lighting. He has propane fireplace for supplemental heat.
Am I wrong to think he would overload the 12/2 wire to that outside outlet. He was going to make up a wire with two male plugs to transfer power into the house from the generator on his covered deck?
/ Generator and electricity flow #2
There are a lot of things that are possible but not advisable. Both of these fall into that category. Any miscalculation could result in a disaster.
/ Generator and electricity flow #3
What I did when I built my house is put in a small sub-panel that feeds my fridge, freezer heating and a few lights. Between this panel and my main is a 30 amp double pole double throw switch that allows me to select whether I get power from my main panel or my generator. This way you don't have to worry about pulling breakers or back feeding and powering up the whole neighborhood. Local power company gets edgy when trying to fix outages and they hear generators running. I have a 8K genset with a jumper to a male receptacle in a covered area outside.
/ Generator and electricity flow #5
Are you saying he's going to backfeed the 220 receptacle and the 110 at the same time, or do the 110 instead of the 220? Backfeeding the 220 will provide power to any circuit in the panel, including the 110 circuits. Backfeeding the 110 will only provide power to the circuits that are on the same phase as the circuit he's backfeeding from. So it's possible he would hook up to the 110 outlet and not be able to power any of the devices he wants to power.
Yes you're wrong, the circuit breaker on that circuit will trip if he tries to backfeed more than it's rated for. So the wire is protected. What he's doing can be really dangerous, as others have said. The cost for a transfer switch is small in the grand scheme of things, and makes this much easier and safer.
/ Generator and electricity flow #6
Yep, back feeding 110v will only power 1/2 the panel.
Chris
/ Generator and electricity flow #7
there are soooo many things wrong with this scenario, that ill not even venture a response. there are maybe 30 other posts on this site about backup generator systems, and every-time i state how it NEEDS to be done to be safe..there is fighting.
/ Generator and electricity flow #9
There have been so many discussions of this on TBN. It's possible to do it safely, it's also possible to cause lots of damage or loss of life by doing this.
Thanks to all who answered my original post. The 220V generator is at his nephews house. The uncle (110V generator) lives in another area and is a BS at times so I don't know if he was really serious as his past use of the generator involved extension cord use only. I'm glad you all agree about how hazardous this idea is. Again Thanks
(This original post pertained to loss of power during a storm and not meant to avoid paying for power from utility)
/ Generator and electricity flow #14
I'm interested in installing a safe and approved method of plugging my portable generator into my house.
All of the schemes and transfer switches I've found seem to require that I have room for additional breakers.
It looks like all my spaces have been used up. Is there a simple solution for me or do I have to buy a new house?
:eek::eek:
Thanks for any advice.
/ Generator and electricity flow #15
Contact a licensed electrician.My transfer switch is outside on the pole.
/ Generator and electricity flow #16
I recognize the value of that advice but "professionals" around here aren't necessarily trustworthy and my budget for this project is less than a million dollars.
/ Generator and electricity flow #17
/ Generator and electricity flow #18
...All of the schemes and transfer switches I've found seem to require that I have room for additional breakers.
I looks to me like you have standard-width breakers in all your slots.
You can purchase double breakers, which fit into a standard slot, but have two 1/2 width breakers in them. If you buy one of these, a minor re-adjustment of the wires inside the panel will free up one slot. No new house is required.
While this is a DIY project for many, the nature of your question leads me to believe that you would be far better off to get an electrician, or at least a very knowledgable friend, to help with this project. Freeing up one slot in your breaker box is a relatively easy job, an electrician can do this in less than an hour. What you want to do with the newly open slot is a different matter, but get professional help there too.
/ Generator and electricity flow #19
Howdy,
Since its looks like your using a mainline panel (Square D) You could go with a interlock kit. The interlock kit will want to use the top right 2 breaker locations. You would then want to add in some half breakers to squeeze the right side down as to fit the new breakers. You gather 2 15amp circuits and use one slot which has 2 indivdual breakers, and the same thing would be for 2 20amp circuits. This way, you could have a dual pole 30amp in the top right with proper interlock, and run the wire out to a generator recepticle. er... with a rough calcualation.. about $55 interlock, $12 half breakers, $20 2-pole 30amp, some 10 wire ($10) and a outdoor recepticle ($60) and your time. With this method, you will then have to manage what you power up and use. But, you would have access to anything in your panel. Of course up to the generator's power limit.
Here is a topic about this very thing generator-transfer-switch-connection-choices
2008 Ford F-350 4x4 Crew Cab Emergency Service Truck (A64556)
2008 Ford F-350...
1999 PETERBILT 379 ROAD TRACTOR (A65054)
1999 PETERBILT 379...
Ground Protection Mats (A64194)
Ground Protection...
1980 19ft Sailboat w/ 2018 Continental Trailer S/A Boat Trailer (A64557)
1980 19ft Sailboat...
MASSEY FERGUSON 50 TRACTOR (A64278)
MASSEY FERGUSON 50...
2007 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2007 Nissan...
