New Grapple exceeds expectations
   / New Grapple exceeds expectations #91
I have had a 66" GRM series clamshell or root grapple rake and I willsay this that both styles have a place where they shine. you can open the rake and drag brush backward into a pile. Whereas the L shaped grapple you can lay items in and not rely on the grapple to hold it in. Each will do 75% of what the other will. The clamshell grapple does keep the load closer to the tractor and help with the weight. Here a couple of links of a couple of my previous threads with pics. You cant goe wrong with either one and like I said there are places one will outdoor the other.
Grapple 1
Grapple 2
Grapple 3
   / New Grapple exceeds expectations #92
I just took Ky's lead, and ordered a GR-S 72" today. I think it would be a great fit on my M7040. Thanks to all on TBN that have contributed opinions and views on various grapples. I'm glad I'm done reading, can't wait to get that beast on my tractor!
I recently bought a Danuser 1025H with an offset FEL mount so I can see the auger bit to the side of the hood. I like the FEL mount with hydraulics over a 3 point set up. You can reverse the auger with the hydraulics in case you get it stuck under a root or rock. Also the FEL keeps the top of the auger so much more in alignment with where you want the hole than a 3 pt hitch. I have a 15" bit and I have it down to about 90 seconds to auger a hole deep enough for a RR tie half way deep. More time than that if there are rocks. Your grapple hydraulics on the FEL should be all you need for the auger. If you do get a hydraulic one for the FEL, don't get the skid steer style with the auger in the middle, you will need a spotter on the ground.
I'll have to look at Danuser. Are you well satisfied. I think EA sells it but not sure
   / New Grapple exceeds expectations #94
Yes I am and yes, I bought it at EA. Ask about a TBN discount. Make sure you get the offset in the second picture. I don't have my own pictures but here are the stock pictures.
Your welcome! I think you will be well satisfied. Thanks Dex3361 and everyone for posting pictures. It really give us different ideas to use our grapples. It also gives TBN members who may be looking to purchase, get a better perspective and allow for a more educated decision.
   / New Grapple exceeds expectations #96
:cool2::cool2::cool2::cool2::cool2:
Glad to hear your getting a new grapple! That will be GREAT setup on your M7040! We're all looking forward to PICS!
   / New Grapple exceeds expectations #97
The L grapples are by far the most popular style that we currently sell but variety is good. We probably sell 20 L style to 1 C style grapple rake however we are also going to make a C style with a one piece lid using the same weight conscious engineering as the Wicked Grapple.
Just curious- why are you only going to use a single grapple on the "C" / rake style grapple?
   / New Grapple exceeds expectations #98
Yep, I will post pics. Delivery should be in about 2 weeks.
   / New Grapple exceeds expectations #99
O.K. I officially have grapple envy. Nicely done.
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
Unused 2025 CFG Industrial QNT45 Mini Excavator (A50322)
Unused 2025 CFG...
2023 BOBCAT T76R SERIES SKID STEER (A51242)
2023 BOBCAT T76R...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52128)
Toyota 6FGU25...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
