Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #1,401
First attempt with a FEL. Disappointed but I understand there is a learning curve. Snow was crazy heavy. Just got 10" of light powder but went with the plow truck because I was pressed for time. Looking forward to trying FEL on a regular storm. I haven't given up yet.
   / Pictures of your snow weapons #1,402
A FEL is not an efficient method to move snow. Blower and/or blade work better. FEL is last resort when snow is so high it can't be pushed and must be carried out of the way.
   / Pictures of your snow weapons #1,403
First post here. After blowing snow for years with my B6200 and rear mount snowblower, I am tickled as can be to be blowing snow while looking forward from my heated box!
That is an L2052-1 blower on the front of my F3060.
   / Pictures of your snow weapons #1,404
   / Pictures of your snow weapons #1,405
Welcome to TBN. Nice setup you have there. Agree rear snowblower is a pain in the neck.
   / Pictures of your snow weapons #1,406
Well, it works for me but a front blade would be easier.
   / Pictures of your snow weapons #1,407
Never had a chance to try it, but I think a v-plow on FEL arms would work pretty well. A plow on FEL arms would be able to stack snow high and push over the tops of piles. The v-plow would make it easy to corral the snow for cleaning off wide areas.
I use the FEL bucket and a rear PTO blower, that combination gets the job done too, but a v-plow running in float might be faster I think.
   / Pictures of your snow weapons #1,408
With a little practice the FEL will do fine.
   / Pictures of your snow weapons #1,409
   / Pictures of your snow weapons #1,410
+1.
Takes forever to clear my driveway using the bucket.
I do it with a loader mounted snow blade in a fraction of the time.
38" X 53" X 16" FUEL TANK (A58374)
38" X 53" X 16"...
1753 (A58375)
1753 (A58375)
2011 Komatsu GD655-5 Motor Grader, S/N 55088 C014007, PIN# KMTGD026P01055088, Turbo Diesel Engine, (A59076)
2011 Komatsu...
HAY SPEAR, 3PT (A58374)
HAY SPEAR, 3PT...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
3PT POST HOLE DIGGER W/ AUGER BIT (A52708)
3PT POST HOLE...
