Buying Advice Kioti DK40SE HST(C) Versus LS R4041H
   / Kioti DK40SE HST(C) Versus LS R4041H
In the 40-50hp range, it is very close with ALL the tractor manufacturers IMO. Pretty much comes down to personal preferences. I think that you will be very happy with the 4047. The only thing that you might check on ASAP is what it would cost to get the 3rd rear remote . You can never have enough rear remotes. None of us are getting any younger and having hydraulics to make our adjustments sure is nice. :thumbsup: At least this way you would have the full capability of your machine at your finger tips. ;)
Great idea! I was going to send my dealer a note about having a tooth bar added to the bucket, and will ask about a 3rd remote at the same time.
   / Kioti DK40SE HST(C) Versus LS R4041H #32
Be sure to come back after you have used the LS for a bit and let us know how it is going. Also, don't forget
The all important pictures....Congrats on the aquisition...
tom
   / Kioti DK40SE HST(C) Versus LS R4041H #33
Just wanted to know. Did you fill each tractor's bucket with dirt ,etc, to see whitch 1 would lift more weight ??
Congrads. on your new ride :thumbsup::cool2:
tom
Will do...it's just a bit of a step up from my 8N, so I can't imagine I'll be unhappy!
Thanks, I'm pretty jazzed about it. In fact, I can't wait for it to get here, because I've got projects lined up that will keep it busy for a long time!
No, I didn't try filling the buckets (sort of hard to do with a foot of snow everywhere). If the literature is correct, the Kioti loader will lift about 260lbs more, and has a max height that's about 10-11" higher. That was definitely one of the big pluses for the Kioti.
   / Kioti DK40SE HST(C) Versus LS R4041H #36
I have had the "EZ" version of the 4041 (2011) for over a year (180hrs) - it has been good to me ... only problems were ones that I brought about. The only irritant I have is that the rad hose clamps tend to vibrate lose every so often ... nothing that would stop me from buying it again. :)
Good to know on the hose clamps! I've been told that its a good idea to go over the entire tractor and loader to check for loose bolts during the first 50 or so hours....certainly can't hurt to check, and add things like the hose clamps.
   / Kioti DK40SE HST(C) Versus LS R4041H #38
And when you drop the bush guard to open the hood remember to hook it back up - otherwise you will find out the hard way the next time you use your loader! :)
Ouch!
Had to stop at the dealer to sign the finance paperwork (needed the serial #), and my shiny, clean, new R4047H was all ready to go....can't wait to get her dirty! That didn't sound right, but you know what I mean :thumbsup: They're delivering on Sat. Pictures to follow shortly!
NEW Fork Extensions (A59000)
NEW Fork...
Hydraulic rail grinder (A56435)
Hydraulic rail...
2017 GMC SIERRA 1500 (A58214)
2017 GMC SIERRA...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
