Grading Smoothing newly acquired land.
/ Smoothing newly acquired land. #21
I have bought new blades and plow bolts for these projects and these run about $25/ft. Ought to last me quite a while.
/ Smoothing newly acquired land. #22
Yeah.. Id better get on my horse and pick up the blades. He was selling them for either $50 or $100 for a six foot length, either is a good deal. I think they were 6 inches wide..
Sean
/ Smoothing newly acquired land. #23
OP has a heavy disk and section harrow if I recall in his post. If he has the power to pull them (and turning area) I would hook them together and disk/harrow at the same time. If the hills have a definite orientation, go 45 degree over them then alternated with 45 degrees in the opposite direction, then make a pass 90 degrees to the hills. This should get them in pretty good shape. If not repeat the process by travelling in a 45 degree plane to the high spots. Pulling a large log behind the whole shebang would drag a lot of dirt into low spots also similar to what a landplane would do.
/ Smoothing newly acquired land. #24
Of course once you got it all levelled out, you would need to reseed it.
/ Smoothing newly acquired land. #25
Birdman is right on . Kill the vegetation first . Wait till it turns to dust. Disc with chain harrow behind. A plane is nice , but a box blade will work. Extend top link a bit , fill it up with dirt , open a beverage , and start driving around .If you have rocks or stumps this will leads to more beverages.
/ Smoothing newly acquired land. #26
jenkinsph , I find you to be one of the best contributors on site. My grandperents lived in Roswell , across from The SEARS store , at 203 W summit . We spent alot of time in Ruidoso . Igrew up on the farm in illinois , currently working as union operator. Wouldlove to meet you , and see the operation. I also bleed green . Thanks , Kevin.
/ Smoothing newly acquired land. #27
Hey Kevin thanks for the nice words and pm me if you plan on coming this way. Would be happy to show you around and have lunch or something.
ALLMAND  MAXI LITE 2 V (A67714)
ALLMAND MAXI LITE...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
2012 CAT D60-6 GENERATOR (A67714)
2012 CAT D60-6...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2015 Ford F-350 Knapheide Service Truck (A66736)
2015 Ford F-350...
