Backhoe Reattaching backhoe alignment problem MF 2410 TLB
   / Reattaching backhoe alignment problem MF 2410 TLB #1
porjoh
peterborough ontario
MF GC2410TLB
Hi - I am trying to reattach my backhoe but I cannot get the two lock pins to line up - about 1/8 inch off.
Any suggestions as to what I am doing wrong?
Thanks for your help
   / Reattaching backhoe alignment problem MF 2410 TLB #2
Had this issue at times.... check for dirt/mud on tractor mounts and on the hoe, very tight tolerances so it does not take much to cause an issue. If it is close, use a rubber mallet, sometimes that is all it takes. Angle if tractor compared to backhoe can also causes problems. Be sure both are level.... :thumbsup:
   / Reattaching backhoe alignment problem MF 2410 TLB #3
Use the stablizers to move it around to get it on. A bit if wiggling is ussualy all it needs.
   / Reattaching backhoe alignment problem MF 2410 TLB #4
Make sure the bottom pin cradle is clean, dirt will build up in them w\out the BH on.
   / Reattaching backhoe alignment problem MF 2410 TLB #5
Ditto for dirt in the "cradle" part-- it really doesn't take much at all to throw it just far enough out to have trouble getting those pins in!
Thanks guys for your help.
Happy new year!
   / Reattaching backhoe alignment problem MF 2410 TLB #7
You're welcome! ...So, was it dirt in the cradle(s)?
Yes plus the out riggers need to be about 6 inches off the ground to get things to line up properly.
Thanks
New/Unused AGT Industrial SDA-140T Track Loader (A57453)
New/Unused AGT...
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
2873 (A58376)
2873 (A58376)
INOP Yamaha Timberwolf Four Wheeler (A57453)
INOP Yamaha...
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
