Who has the most hrs .
   / Who has the most hrs . #21
The hour meter seems to be something the stops work on a few of my machines at home that doesn’t get fixed but at work we had a linde forklift (German) with Perkins diesel the same as some Massey Ferguson tractor about 80 hp we did 23,000 hours only engine work other normal servicing was to recon the injectors and injector pump as a precaution traded it in on a newer machine and I think it is still going but on light duties
   / Who has the most hrs . #22
1065 hours and counting... had a few glitches in the beginning. Seems to be running fine now.
   / Who has the most hrs . #23
I do wonder what kind of long term durability testing the manufacturers do on CUTs? Kioti does atleast sell the same engines that are in the tractors separately for industrial use so I imagine the motors should go for many many 1000's of hours.
My plan is to keep the tractor under cover for its whole life and just fix what breaks or wears out as it comes. Hopefully it will go 30-40 years at 100-150 hours per year. I don't really see why it wouldn't with good maintenance.
   / Who has the most hrs . #24
You might want to split the tractors into power categories.
Some of our higher houred tractors, all still running fine & capable of putting in a hard days work:
*Equal to/less than 150hp-
MB Trac1500 150hp Mercedes @ 9,600hrs (pictured)
White 4-150 150hp Cat V8 @ 6000hrs
Fiat 780DT 78hp Fiat @ 6000hrs
Allis Chalmers 7580 6cyl Allis @ 7000hrs
Deutz DX140FWA 130hp Deutz 6cyl @6500hrs
*Greater than 150hp & less than 300hp-
Versatile 835 230hp 6cyl Cummins @ 13,000hrs
JD8440 215hp JD 6cyl @ 8300hrs
JD6030 212hp JD 6cyl @ 5900hrs
*Above 300hp-
Steiger CP1400 400hp Cat @ 29,000hrs
3x Acremasters 330hp V10 Mercedes @ 20,000-36,000hrs
+ Adding our high houred Lawn Tractors/CUT's to the list above:
JD LT155 15hp kohler petrol @ 1070hrs
Iseki TX2160 @ 2600hrs
Kubota B7100HST FEL/BH @ 6300hrs
   / Who has the most hrs . #25
My CK is 13 months old and I just hit 57 hours. And let me tell you, she still purrs like a kitten. :)
My wife's grandfather just got one of his tractors back a massy ferguson1020 with 8,000. The only thing major done to it was new tires and clutch. I'm hoping that my kioti dk 40 dose make it that high with out a lot of issues.
   / Who has the most hrs . #27
How does one put on that many hours for a machine with only 20 HP?
As he says he babied it. They used it mostly to power there camp with a pto gen. I thinking of buying it he's think of selling it for 5,000. I would like a small tractor to do light work.
   / Who has the most hrs . #29
Way to much for that mower.
   / Who has the most hrs . #30
The hour meter seems to be something the stops work on a few of my machines at home that doesn稚 get fixed but at work we had a linde forklift (German) with Perkins diesel the same as some Massey Ferguson tractor about 80 hp we did 23,000 hours only engine work other normal servicing was to recon the injectors and injector pump as a precaution traded it in on a newer machine and I think it is still going but on light duties
Within reason the hour meter is the last thing i look at . Mechanical condition first , Cosmetic second then hrs last . 4 of our tractors have not had a working hr meter for 10 years or more .
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
30ft Highway Trailer Co. Lowboy (A55315)
30ft Highway...
2008 Sterling Acterra Ambulance (A56858)
2008 Sterling...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
