BX Expanded Work Light Kit
/ BX Expanded Work Light Kit #1
magnatic
Southern Ontario
2006 BX2350
I'm planning to order these lights and I would like to hear from those who have used them as to if there is a noticeable difference in performance between the 4 3/4" and 6" lights, and if the 3 light kit would be necessary/superior to the 2 light kit. Any help from owners would be appreciated. Thank you.
/ BX Expanded Work Light Kit #2
I just installed the 4 3/4"-2 light kit a few weeks ago. I mounted them on the ROPS under the top of my BX25 to give them a bit more protection from stray branches, etc. They really do light up the night especially with the headlights on too. They will basically be used seasonally during the winter with the front snowplow. The install was pretty easy once I found and removed the tape from the extra power wires on the tractor. In hindsight, I should have purchased the 3 light kit because there is a need to see when backing up on those cold dark nights. All parts seem to be of good quality and everything needed for the install is included. I'm happy!
/ BX Expanded Work Light Kit #3
In my case, I was in a hurry to get it done for an upcoming hay ride. So I ordered the small set of two and they worked fine for me just like paulemar. If one wants to get more involved in such lighting, he could spend quite a bit more or a bit less. The BX-Expanded product does just as it describes and served me well on the BX. I then transfered them to my new Kubota B2620 where they hooked up just as easily. I think my BX2660 could have handled a three light set up, especially if there were a seperate set of switches. Cheers Mike
/ BX Expanded Work Light Kit #4
I have the smaller set and they throw plenty of light. I have a front mount snowblower and the stock headlights are effectively blocked by the blower (and the FEL when it's being used) so these lights are an excellent addition. You'll like them--plenty of light from the smaller ones.
/ BX Expanded Work Light Kit #5
I got my father a set for XMas, went with the smaller set and just 2 of them. Now I wonder if a 3rd for backing up would have been a good idea.....dammmmmm.
/ BX Expanded Work Light Kit #6
I'll probably wait until this coming summer, but I think I'll add an LED facing the rear. There are only 2 wires to tap the new light into, so that will be the easy part. Making a decent looking, functional, mounting bracket will a little more of a challenge. It's too bad they don't make an add-a-light kit or sell the mounting brackets separately for those of us who now think the 3 light option would have been a better choice. Hint, Hint!
Thank you so much for your advice. Based on your recommendations, I just ordered a 3 light set of the smaller lights. I appreciate your help.
/ BX Expanded Work Light Kit #8
I think my work light circuit is only 10 amps. Does anyone know what the three lights draw for amps?
/ BX Expanded Work Light Kit #9
According to BX specs, the three light set draws 13.5 amps. But BX can correct me if I'm wrong. Call BX if you want more info. They are quite helpful.
/ BX Expanded Work Light Kit #10
This is kind of what this thread is about, I think. I added three 27 W LED work lights (two forward, one back, switched independently) which will draw, if all on at once, less that 7 amps. I like the LED lights, having had them, along with conventional incand. work lights, on my last tractor.
/ BX Expanded Work Light Kit #11
I got my dad 2 for christmas 3" as well.. 1 faces forward 1 faces rear, more than enough light...
Only problem is one of the springs is MIA and BX-Expanded will not respond back to my emails, so i have to figure out how a new way to mount.
/ BX Expanded Work Light Kit #12
Here's a couple of photos of how I mounted my lights... (before anyone comments on using grade 8 hardware, let me just say I wanted to match the ROPS hardware)
/ BX Expanded Work Light Kit #13
We've come to expect that emails always get through to the intended recipients. Unfortunately, that just is not the case. We frequently reply to an email and have it rejected by the senders account. They also get blocked by spam filters. I'm sure it happens with our incoming emails as well.
I looked through emails and don't seem to find one relating to light parts that has not been answered.
Note: the name is BXpanded, not BX-Expanded. If you are sending to an address using that, we won't get it.
contact@bxpanded.com
Just give us a call 704-419-5332
Harry
/ BX Expanded Work Light Kit #14
Got taken care of today by kristen, All is well.
I used the "contact" button on the website, email must have just gotten lost in the internet
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
2023 Boxer 700HDX Compact Skid Steer (A63109)
2023 Boxer 700HDX...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2013 CORPUS 40FT  T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
