Snowblower Height
/ Snowblower Height #1
JUBILEE1953
Ohio
MF 1742 TLB - Ford NAA
I just attached a BX2750 snowblower to my BX25. I noticed that the skid plates were up off the ground. With the bottom blade resting on the ground will it damage or mark concrete or asphalt?
/ Snowblower Height #2
You will certainly wear your edge bar on the blower. You should adjust the skid plates so that edge bar is a bit above the surface you are blowing. When it snows, ice etc will also lift the blower above that point. I replaced my skid plates with wheels to get around the marking issue.
/ Snowblower Height #3
Yeah you dont want to be on the scraper. I believe the shoes are all the way up when it comes from the factory (i think mine were). If your on asphalt you can run on the first hole on the shoes, mine, due to the gravel drive are all the way down to give maximum clearance between the scraper and the drive.
/ Snowblower Height
Do you have a pic of the wheels?
/ Snowblower Height #5
Don't forget that the length of your top link will also have an effect on the height and angle of your cutting edge. Once I got the skids adjusted where I like them and fine tuned the top link, I measured the length of the top link and wrote it on the side of the blower with a sharpie marker. This way I can set everything up instantly whenever I change out implements. Hook it up and use a tape measure to match the top link to the number on the blower. No more messing around.
Joe
/ Snowblower Height #6
I used a set of fixed wheel casters.
/ Snowblower Height
Thats a great idea to keep in mind. It wouldn't help me due to my snowblower is front mounted.
Joe
Hays LT1 Tender (A61307)
Hays LT1 Tender...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
207283 (A52708)
207283 (A52708)
UNUSED JCT 84" SNOW PUSHER (A62131)
UNUSED JCT 84"...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A63118)
FRESHLY...
1990 Jeep Wrangler Multipurpose Vehicle (MPV), VIN # 2J4FY29T5LJ516997 (A61165)
1990 Jeep Wrangler...
