John Deere 4410 not moving when peddles pressed
   / John Deere 4410 not moving when peddles pressed #1
chrise2312
Edmonton
John Deere 4410
Hello, we have a JD 4410 at our business we use for moving trailers. Recently when pressing forward or reverse peddles it is very sluggish, is this a low oil problem and where can I check levels, and where would the filler hole be.[/B]
   / John Deere 4410 not moving when peddles pressed #2
:welcome:
   / John Deere 4410 not moving when peddles pressed #4
Could be stuck brakes, it's a common issue esp on HST's. Search the forums for this issue.
   / John Deere 4410 not moving when peddles pressed #5
If the engine strains when you go forward or reverse then check the brakes. If it just moves very little but the engine doesn't seem to strain then check the oil level, also sometimes tractor linkage pins fall out so don't overlook this either, especially if the Hydro level is good. Have someone step on the pedals and check the linkage while they do.
   / John Deere 4410 not moving when peddles pressed #6
This is a "E" Hydro machine so there are no linkages. Is there any codes flashing?
   / John Deere 4410 not moving when peddles pressed #7
Right, I didn't know what box the 4410 had.
   / John Deere 4410 not moving when peddles pressed #8
On my 4720 I have had occasions when the brake lock was set and the indicator light was not lit. Push the brake to the floor and make sure the brake lock is released.
   / John Deere 4410 not moving when peddles pressed #9
If the engine does not load down at all when you push the pedals then you may have computer program problems. I have had that issue with my 4520 and supposedly the dealer found a bad connection on the ground strap.
   / John Deere 4410 not moving when peddles pressed #10
Yes, I would check the connections at the box attached to the pedals. There are several methods of sensing pedal change in vehicles (hall sensors, IR sensors, etc.). I don't know how Deere does it but there has to be a wired link between the sensing unit and the main computer. Could you have snagged a wire going to it? A bad connection?
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
197390 (A50459)
197390 (A50459)
2014 INTERNATIONAL PROSTAR (A50854)
2014 INTERNATIONAL...
CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A50458)
CATERPILLAR D8T...
