WR Long elec over hyd valve help!
   / WR Long elec over hyd valve help! #1
oscar94
Hi guys...enjoy reading all of threads! Could use a little help if possible.
I have an L5030 with a LA853 fel and want to hook up the wr long valve and grapple. I am not sure which hose to disconnect from the tractor and connect to the P side on the WRLong valve.
Here is a picture of the hoses. One of these must be disconnected and reconnected to the WRLong valve. Don't know if it is the top or bottom one. Also a pic of the valve on the fel if that is easier to tell.
Also...anyone have any hints on how to route this little hose from the valve body on the tractor to the T side of the WRLong valve? Seems like it needs to bend quite a bit.
If anyone has any pics of their own set up and want to email it to me I would welcome it!!
thanks
   / WR Long elec over hyd valve help! #2
I have the WR Long valve for the grapple. I'll take some pics in the morning for you.
thanks!! i really appreciate it.
   / WR Long elec over hyd valve help! #4
thanks
I am new to this site and have a L4330 with an LA853 FEL and have the same question as above.
   / WR Long elec over hyd valve help! #5
Maybe like this .
They both appear to be the same.
   / WR Long elec over hyd valve help! #6
You may notice that initial post was from 2010, would hope he got it hooked up by now. Maybe threads over 2 years old need to be locked or something to keep this from happening
David Kb7uns
   / WR Long elec over hyd valve help! #7
Maybe like this .
JJ thank you for the attached pages, this will help me greatly to install the plumbing correctly when I receive the valve.
Have a great holiday.
Peter
   / WR Long elec over hyd valve help! #8
Just hooked up mine in November. As I recall, Kubota has color tape on the hoses. The one with the green label is the one you disconnect from the hydraulic block and connect to the WR Long valve. I had to put a loop in the short hose to take up slack and connect from the WR Long Valve to the hydraulic block.
   / WR Long elec over hyd valve help! #9
Herkypilot, is there a chance that you could post some "good" pictures of your 3rd function valve, hoses and control switch? ;)
   / WR Long elec over hyd valve help! #10
Brian,
I can, but it won't be until next weekend as my tractor is on my property out of state. Going there next week. My install looked a lot like this poster who installed his on his MX. I have a few differences. He hooked his power wire to the starter. I found one that is key activated under the panel which was protected by a 10 amp fuse.
http://www.tractorbynet.com/forums/kubota-owning-operating/192572-w-r-long-kit-plus.html
BTW, Brian, I contacted you earlier in the week about getting the tilt hydraulic setup for my tractor. I should have an answer on the QD size too.
Cheers,
HP
Booster Cables (A59230)
Booster Cables...
2024 Frontier FL1061S Hydraulic Flail Mower (A56438)
2024 Frontier...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
2016 Chevrolet Traverse SUV (A59231)
2016 Chevrolet...
2022 Ram 2500 (A55973)
