JD 4300 Hydraulic Fluid level
/ JD 4300 Hydraulic Fluid level #1
texasyankee
austin, tx
jd4300, jdlx255
I cannot see the "float" in the fluid level window by the pto shaft. If I have put in too much fluid would I still be able to see the float?
Please be gentle on me ... :)
Here is a picture of what the "float" should look like from the manual. I have seen this but need to remember to check every time I use tractor. I guess my question now becomes will it harm the tractor if I put in too much fluid? All the manual says is that is will cause it to overflow.
/ JD 4300 Hydraulic Fluid level #5
I don't know what the plastic piece is but really don't think it is a float the Mighty Dodge is right there should be a horizontal fluid line in the middle of the window white disc may be to facilitate seeing the fluid YOU NEED TO ADD THE RIGHT AMOUNT TRANSMISSION FLUID NOW
/ JD 4300 Hydraulic Fluid level #6
Thanks guys I will look for that, I thought maybe there was a plug or dipstick
/ JD 4300 Hydraulic Fluid level #7
It is difficult to see the hyd level in the window without adding JD hyd dye.
/ JD 4300 Hydraulic Fluid level #8
Look closely... It may be over filled and the sight glass is completely covered.
/ JD 4300 Hydraulic Fluid level #9
John Deere hyd. red dye
part # MT3668
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
72in. Land Plane (A65640)
72in. Land Plane...
2016 Kubota SSV75 Compact Wheel Loader Skid Steer (A64553)
2016 Kubota SSV75...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
YALE FORKLIFT (A63291)
