Yet another bucket-mod thread
/ Yet another bucket-mod thread #41
mjncad said:
Do I claim that this is the best and safest rigging setup? No, not in the least, and I understood the risks involved and deemed them to be acceptable for a one-time only project. I just wanted to illustrate that a receiver on a bucket can be used for more things than just moving trailers.
A great balancing job on that slab !
Here are the pics.
The perfectionist in me is tempted to grind smooth some of those welds and try to go over them again and make them look nicer. The pragmatist in me says that I'm not likely to make them look any nicer the second time than I did the first time! Practically speaking, however, I wonder if some of them are a bit thin and need to be gone over again--like, for example, the right-most one in the last picture. I was working with 3/32" rod because the bucket is 1/8" and I didn't want to burn through. Now that I've got a pad of metal from the existing bead, I wonder whether it would be worthwhile to go back over it with 1/8" rod. It's possible that the larger rod will do a better job of filling the joint smoothly and maybe look nicer too. What do y'all think?
BTW, this morning, I remembered another "tip" that I'm sure I'm not the first weldor to figure out: when I was having trouble getting a good ground on the flat stock, another thing I did was take the receiver tube (a five-pound hunk of un-painted metal) and just clamp the ground clamp to it and set it on top of the work piece. Bingo! Instant ground! Kind of like those magnetic ground clamps you see, except without the magnet. I thought I was pretty clever for coming up with that.
/ Yet another bucket-mod thread #43
If it was me, I would take that 1/8 rod and go over some of those welds on the back side. Clean them up first real well with a brush on your angle grinder, and hit another pass on the weld and a little higher up into the meat of the 3/8 flat bar. I would also do the ends of the flat bar, and I would have tied into the vertical upright "meat" on the bucket. I may go overboard, but it darn sure aint going to fall off when I get done with them. Yes it is interesting when you get a large chunk of metal heated up by welding how long it stays pretty hot..It usually doesn't take me long to inspect it either:shocked:
James K0UA
/ Yet another bucket-mod thread #44
Oh, another thing I learned: tip the hook slightly away from the direction of the first tack welds, so that when they cool, they pull it perpendicular. Otherwise, they will pull it out of true.
As one who welds a lot of hooks, I can verify that! :laughing:
/ Yet another bucket-mod thread #45
I suppose that the welds look pretty good for a beginner. NOW what you need to do is put a grinder blade on and grind all the knots off the weld and make them kind of uniform. Then take some 7018 and run two more passes on each bead. Start with one of them on the bottom and keep the center of your puddle on the edge of the weld so you are putting weld metal on the base and about half of it overlapping the original weld bead. Clean it up with power brush to remove all the slag then weld another bead on top of that one. This bead should tie into the bottom bead and overlap the top edge of the original bead. One the first pass your rod and should be about 45 degrees from horizontal like thus?/ more or less. The 2nd pass the rod needs to be more horizontal and pointed into that undercut. Go slow and let the 7018 fill in that undercut but firs make sure that you grind it so you have removed all the porosity and slag from the undercut. If you prep those ugly welds with a grinder to make them smoother and more uniform, your subsequent passes will look lots better. Welding over ugly just makes more ugly. I learned that early in my welding career. If you mess up say by not properly cleaning the metal and the weld comes our with bug holes (porosity), lumps, low spots etc, that is why they invented grinders. Grind it fairly smooth and weld over it. The secret to smooth uniform welds is travel speed. Keep it fairly constant unless you have a low spot to fill in then just a bit of hesitation to let the rod burn a little longer there then start back with you normal travel speed. Most beginners try to travel too fast, slow down and give the rod time to burn and most of that undercut will fill in unless you are running way too many amps.
Many of your welds are a little skimpy so extra passes are needed anyway. Leave 2 or 3 smaller beads on your cap (top pass) rather than trying to make one huge pass.
Finally weld all the way around the hook. This will keep moisture from getting underneath it and rusting out the plate underneath. You may get a small flare like a little volcano from vent gas when you finally close it off but just let the flare die down and the weld cool off then fill in the little hole.
I attached a couple of photos of my hooks and a bracket I built but the braket photo isnt very good but I cant delete it> You can see how I wrapped the weld around the hooks on my Kubota
Gary: Funny you should say that. I decided that "good enough" wasn't good enough, so I started grinding the welds mostly off and going back with 1/8" 7018. Here are some pics.
IMG_1208.JPGIMG_1209.JPGIMG_1210.JPGIMG_1211.JPGIMG_1212.JPGIMG_1213.JPGIMG_1214.JPGIMG_1215.JPGIMG_1216.JPGIMG_1217.JPGIMG_1218.JPGIMG_1219.JPGIMG_1220.JPGIMG_1221.JPG
I'll go back and weld all the way around the hooks.
/ Yet another bucket-mod thread #47
OK much better. I would wrap the welds all the way around the corner and across the end of your flat bar. That is where any strain would tend to concentrate the forces. Also if you have a 3/32 7018, put another pass on the hook where you still have some undercut on the top edge and weld them all the way around if possible. Ends dont have to be much more than water tight. It looks better that way. Also since all the force is going to be pulling toward the front of the FEL, make sure all the welds on the side nearest the tractor are very good welds. That 7018 makes a much prettier and stronger weld.
/ Yet another bucket-mod thread #48
OH YEAH, congratulation on joining the bucket hook crowd.
/ Yet another bucket-mod thread #51
Welding and concrete work are simple in concept; but a lot more difficult to do in reality.
You said it!!!!! and that's differance between the pro and the amateur. But most of my concrete work is...
a. not settled b. not cracked c. not pretty.:D
Here's a few photos from today's work. After grinding out nearly all of the 6011 welds and going over with 7018, I am adding a 2nd and 3rd pass, building up weld in the joint. I also welded the sides of the base plate and closed off the hooks per suggestions here.
I just got done putting the last set of beads on and grinding off a few little bits of spatter. Tomorrow's task will be putting on the receiver tube.
/ Yet another bucket-mod thread #53
I have to say those welds dont look half bad. You are getting the hang of it. NOW if you can do that in all positions you will be on your way to becoming not a slow welder or a fast welder but a half-fast welder.
/ Yet another bucket-mod thread #54
Joshua, your welding is getting better and better.. Keep at it.. I am just a Half-"fast" welder myself, at best, on a good day.:)
James K0UA
Thanks, James and Gary. I think that first pic on the left is one of the better beads I've ever run. I'm right proud of it. The fact that that one was better than the others is more luck than skill, but the fact that I got even one looking like that says to me that there's at least a smidge of skill in there.
All done! Just need to paint it up and take some final pics. I have got to remember the way that welds cool. The receiver tube is cocked just a few degrees to one side because I welded one side up before welding the other. I thought that the tacks would hold it square, but no dice. So I guess the right thing to do is a few inches on one side, then a few inches on the other?
/ Yet another bucket-mod thread #57
Joshua, you have probably seen this before, but it is well worth watching again. It deals with tackups and "pulling" and how to overcome it.
ARc Welding Project -Everlast PowerPro 256 - YouTube
James K0UA
/ Yet another bucket-mod thread #58
Lots and lots of clamps go a long way to keeping things from creeping around during the welding process.
/ Yet another bucket-mod thread #59
I was going to pop in with a comment after seeing your first weld passes but you've improved on them greatly so no need. I would spray the bare metal with self-etching primer before painting though.
Ditto on the tooth bar.
Thanks for the compliment. Those first beads were pretty bad, and I'm glad I went back and ground them out. I still have a lot of practice to do with 6011, but as long as 7018 keeps working for me, I may never get to it. ;-) I mean, I will probably do it some day, because 6011 is such a bread-and-butter rod that I couldn't respectably show my face if I could work it, but I have a long way to go with "easy" rods before I need to start challenging myself like that.
Here's a photo of the finished job.
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
Kubota M4700 (A60462)
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
2021 INTERNATIONAL LT625 (A63569)
2021 INTERNATIONAL...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
John Deere 4240 w/ Buhler 695 Front End Loader (A64047)
John Deere 4240 w/...
