What to do to my CK20S HST in the winter?
   / What to do to my CK20S HST in the winter? #11
It's probably obvious, but make sure the antifreeze in your coolant is up to the lowest temps you expect to see. If in doubt, change it out. Also, an oil change before long-term storage will ensure the acids and other products of combustion aren't there to attack the metal over the long winter (assuming you haven't changed the engine oil recently).
   / What to do to my CK20S HST in the winter? #12
I make sure my anti-freeze protection is good to -50F. That would be a little better than a 50/50 mix of eythelene glycol to water. Say about 60/40. You don't want to get much stronger than that.
   / What to do to my CK20S HST in the winter? #13
... a little better than a 50/50 mix of eythelene glycol to water. Say about 60/40. You don't want to get much stronger than that.
Right you are! Too much glycol not only produces a less effective "anti-freeze" mixture but also risks gooey glycol-based deposits inside the motor that can inhibit heat transfer (too much of a good thing).
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
2007 Ford F-450 Ambulance (A55788)
2007 Ford F-450...
2012 Ford F-250 (A55973)
2012 Ford F-250...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
Hustler super Z zero turn (A56857)
Hustler super Z...
2016 Club Car Carryall 710 Electric Utility Cart (A55853)
2016 Club Car...
